no start up when cold #668293 11/19/05 09:48 PM
rebelboydylan Offline OP
my 91 4.0L yj won't start when its cold. when it's warmed up it starts fine, it cranks but i have no fuel or spark untill i keep on cranking then it will start after a half hour. my relays are fine my grounds to my ecm are fine i have no water in anything. i was thinking it was my crank pos. sensor but why would it be affected in the cold? Why does the cold effect it this way? Any sugestions?
91 yj renegade with 4.5" lift 33x10.5s wanting to be a rock eatin machine
Re: no start up when cold [Re: rebelboydylan] #668294 11/19/05 11:27 PM
If you arenÆt getting any spark cold, it is either the Crank or Cam position sensor (or computer, but that is highly unlikely). First off just disconnect the cam and crank sensors and clean out the connector. If those are dirty you might have solved the problem. If it still won't start get you there with a hair dryer and heat up the crank position sensor then distributor. If it starts after some heating of the sensor, replace it.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.5846 MB (Peak: 0.6337 MB) Data Comp: Off Server Time: 2026-11-18 11:44:54 UTC
