Gen 2 Trooper V8 swap #668378 11/20/05 07:03 AM
Rhino58 Offline OP
Am looking to put Olds Aurora 4.0 V8 in my trooper. I understand that the starter on the Olds sits on top side of the engine, so the Isuzu bell housing won't work. I have the 4L30E trans but haven't looked to see if it has a removable bell housing that I can swap with the Olds. Any ideas or help would be greatly appreciated. Thanks! Gary
Re: Gen 2 Trooper V8 swap [Re: Rhino58] #668379 11/20/05 08:19 PM
JLEMOND Offline
The bell housing is removeable in that in unbolts, but the backside where it attaches to the trans is also the vlv control circuit for part of the overdrive assy where the oil pump goes thru the part you are talking about , it is not removable as a bellhousing in the true since of the word, that you could just bolt on another bell, but it should bolt to the olds eng as it uses the small bolt circle of the 60 degree eng, all isuzu v6 engs use 2 bolt circles both are the 60 degree design , the inner circle is for the automatics and the outer circle is for the manual shift , just have to watch for the dowel pin location,Jerry
Re: Gen 2 Trooper V8 swap [Re: JLEMOND] #668380 11/25/05 02:12 AM
trooper_91 Offline
I have a 91 Trooper 2.8L v6 auto, with a bad trans and a motor that's about to go out
<img src="/forums/images/graemlins/barf.gif" alt="" />. I want to step up, could someone suggest a motor and trans to swap into.
I'm sure this has been discussed before please direct me to that link or post.
Thanks
<img src="/forums/images/graemlins/baby.gif" alt="" />
What, Where, how did I get here again?
Hey guys....how do I get it in 4 wheel drive?
Re: Gen 2 Trooper V8 swap [Re: trooper_91] #668381 11/25/05 03:13 AM
4WDJOE Offline
Chevy 3.4 <img src="/forums/images/graemlins/cheers.gif" alt="" />
97 Rodeo
Re: Gen 2 Trooper V8 swap [Re: 4WDJOE] #668382 11/25/05 03:48 AM
trooper_91 Offline
YES SIR! <img src="/forums/images/graemlins/patriot.gif" alt="" /> Which doners should I be looking out for?
Re: Gen 2 Trooper V8 swap [Re: trooper_91] #668383 11/25/05 04:49 AM
Madcat Offline
The donor vehicles that are most used are the '93+ Firebirds and Camaros. These have the starter on the proper side, but a FWD out of a Lumina, or other such car can be used as well you'd just have to drill adn tap the starter holes on the right side. Others will chime in with better details or do a search under 3.4 swap.
Madcat <img src="/forums/images/graemlins/kewl.gif" alt="" />
1979 Pontiac Trans-Am - looking 4 a pontiac 455cid
1988 Trooper II - AMC head, .030 overbore, Calmini cam. Toga HV oil pump, Aisins, soon 2 b turbo
1989 Impulse Turbo - Fidanza flywheel, 270cc injectors, turbo-back exhaust, KYBs F/R
Re: Gen 2 Trooper V8 swap [Re: Madcat] #668384 11/27/05 08:12 PM
trooper_91 Offline
Perfect <img src="/forums/images/graemlins/lol.gif" alt="" /> thanks Mad <img src="/forums/images/graemlins/evil.gif" alt="" />Cat for the info. This will get me started. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Gen 2 Trooper V8 swap [Re: trooper_91] #668385 11/27/05 09:23 PM
Ed Mc Offline
You can't use Front Drivers if they have alum heads; the 2.8 TBI intake manifold won't bolt up. You'd have to completely rewire your EFI system to use the MPFI setup found on FWD 3400's. And you can't just bolt your cast-iron heads to these motors as they have dished pistons; the compression ratio would be extremely high.
Best bet for ease of installation is the Camaro/Firebird 3.4 or a new GM HT 3.4 crate motor.
BTW I have files for this swap, if you're interested send me a P.M. with your e-mail address...........ed <img src="/forums/images/graemlins/kewl.gif" alt="" />
'90 Troop 3.4 LS
'89 Troop RS (Has Valve Issues, needs Counseling)
HI, I'm Ed and I'm a Trooper-holic!
Keep On Troopin'......
Re: Gen 2 Trooper V8 swap [Re: Ed Mc] #668386 12/27/05 08:43 AM
trooper_91 Offline
Thanks for the info, I'll touch base with you. Happy holidays . <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.010s) Memory: 0.6291 MB (Peak: 0.7328 MB) Data Comp: Off Server Time: 2026-11-17 11:29:37 UTC
