Adding another trans cooler during manual to auto swap #671187 11/28/05 05:57 AM
BAD87-2DR Offline OP
I have the factory transmission cooler and I have an aftermarket that is fan forced. My question is, do I add the fan forced in addition to the factory one or can I replace it? Also does the factory cooler have a thermostatic bypass valve or a temperature controlling thermostat of any kind to prevent the transmission fluid from being to cold? Thanks
Rich <img src="/forums/images/graemlins/confused.gif" alt="" />
Active duty US Coast Guard helicopter mechanic (IA)
87 Monty
2.6
auto in progress
31X10.50 mudders
ARB
Warn 6000
Many hours of sweat and pain
Previously Badas87-2dr
Re: Adding another trans cooler during manual to auto swap [Re: BAD87-2DR] #671188 11/28/05 03:24 PM
ForcedAir_Montero Offline
From all I learned during my swap, There is no t-valve for the cooler. The cooler in the bottom of the radiator is actually as much (if not more) of a warmer during cold weather as it is a cooler during hot weather. I don't drive mine much in cold weather, so I did not run through the radiator.
As for the cooler itself-
Don's truck probably saw (prior to 4.3 conversion) a harder life than most, due to long road trips towing a big travel trailer. He replaced his stock one with a cooler with an aux fan. He used one out of a Ford pickup, but your's would be the same setup.
I used the factory one, but it's out of a V6 truck. There is a pretty substantial size difference over the 4cyl cooler, and I've not had a problem
BTW- Glad to see you back at it! <img src="/forums/images/graemlins/kewl.gif" alt="" />
-Dave D
Reservoir of Useless Knowledge
"But... If I kill all the golfers, they'll lock me up, and throw away the key..."
-Bill Murray
'84&change Monty MPI Turbo, choptop, f&r lsd, swapped in AT- All the goodies!
Re: Adding another trans cooler during manual to auto swap [Re: BAD87-2DR] #671189 11/28/05 04:36 PM
BobShaw Offline
You might also want to consider the remote tranny fluid filter sold by Summit.
Bob Shaw
Re: Adding another trans cooler during manual to auto swap [Re: BAD87-2DR] #671190 11/30/05 05:16 AM
AHHH! Why would you get rid of a manual for an auto? I can't stand mine and it works perfectly!
Re: Adding another trans cooler during manual to auto swap #671191 12/03/05 05:07 PM
For rock crawling my friend.
87 Monty
2.6
auto in progress
31X10.50 mudders
ARB
Warn 6000
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6058 MB (Peak: 0.6668 MB) Data Comp: Off Server Time: 2026-10-30 10:23:13 UTC
