Trouble Shifting #671709 11/29/05 10:47 PM
juggernaut Offline OP
I just left the mechanic. He said "felt like like slave cylinder going out" Wanted to run it by yall.
Past month, I have added fluid twice and I have trouble getting her into gear alot. I can usually double clutch and it will work for a couple of shifts then back to not wanting to go in gear. Sounds reasonable to me but....
Thanks
2001 Jeep Wrangler Sahara/4" Rough Country Lift/BFG 32x11.5x15
I caught this "JEEP thing" of your and now it hurts when I pee.
Re: Trouble Shifting [Re: juggernaut] #671710 11/30/05 04:34 AM
Angel Carlo Offline
Before tearing into it you might want to try some stuff from BG called syncro I think. Maybe someone can chime in with the correct name.
Anyway, I had the same problem, changed out the hyd clutch cyl and it still did it. Not to say that's your problem, but for me it wasn't. The BG syncro oil worked wonders. Since then I had to work on my tranny and the shop dumped the oil. I have to getr more because just trying to get it in 1st is hard and 3rd grinds.
1987 Dodge Raider rebuilt Quest block bored .040 over put together, and installed by Shelby. 5spd, '87 stock turbo, Intercooled, 2.5" exhaust. MPI with hard pipes, FIP Pro-4, MSextra MS1
Re: Trouble Shifting [Re: juggernaut] #671711 11/30/05 05:52 AM
Thanks, Ill give it a look.
I actually got out the manuals. I adjusted the play in the pedal and bled and flushed it out. I put 2 botles and and left the port open. I drove it around for a little while tonight and it seemed good. Will see tomorow.
Re: Trouble Shifting [Re: juggernaut] #671712 11/30/05 06:47 AM
DRaider90 Offline
I have had the slave cynlinder on my Raider replaced, and there was no warning really. If I remember correctly it felt like the cluth pedal went out and it just wouldn't shift. If this is the case you will find out, hopefully in your driveway like I did.
88 Raider(Red):160k-Reman'd 2.6-5spd-Weber-SW Hubs-34x9.5 TSL-OffRd Pkg-1"Tbar-2"BL-CB
88 Raider(Silver):No 2.6/Bad KM145 Parts/Project
88 Montero(Brown):No 2.6,4.88s Parts/Project
[b]4X4 STICKERS,SHIRTS,ETC:
4WD Stickers AT COST.[b]
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6013 MB (Peak: 0.6575 MB) Data Comp: Off Server Time: 2026-05-30 01:07:09 UTC
