rear disc conversion #671790 11/30/05 04:13 AM
hdrisc Offline OP
This is for my 1989 buildup that I'm doing.
I called Downey off-road today and got a price of $139.00 for the caliper brackets. Is there another company that is able to sell just the brackets? I thought I've seen them somewhere.
Re: rear disc conversion [Re: hdrisc] #671791 11/30/05 04:35 AM
CraShYota Offline
prolly can get just the brackets from front range offroad. but your still going to need axle shafts.
Welding and Fabrication Engineer
2003 taco V6 ext cab sr5
1988 Toyota Pickup V6(totaled)
Re: rear disc conversion [Re: hdrisc] #671792 11/30/05 05:13 AM
G
Greg_Canada Offline
SKY sells them, much cheaper than the downey brackets, and they also sell everything else you need for a rear-disc convo.
SKY
Click on Toyota then SUSPENSION... scroll down a bit...
89 4Runner
Re: rear disc conversion [Re: CraShYota] #671793 11/30/05 06:05 AM
OOP'S Offline
You do not need axles if you are just doing disc brakes. If you go full floater that you get need new axles plus a bunch of other stuff!!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: rear disc conversion [Re: OOP'S] #671794 11/30/05 01:17 PM
hdrisc Offline OP
Nope, just doing the rear disc conversion. I can pickup the other parts at NAPA. Might need some small parts from Toyota.
Looks like I'll be making a call to Sky manufacturing.
Thanks
Re: rear disc conversion [Re: Greg_Canada] #671795 12/01/05 03:56 AM
DirtyHarry Offline
Toyota Moderator
Personally I would not purchase anything from Sky Manufacturing, but that is just my opinion. I am running the All-Pro disc kit but if you just want brackets you can get them from TSM Manufacturing .
Re: rear disc conversion [Re: DirtyHarry] #671796 12/01/05 05:52 AM
willzrunna96 Offline
you can get the brake lines and calipers from "napa" but you will have to machine the rotors to fit over the axle
Re: rear disc conversion [Re: DirtyHarry] #671797 12/01/05 05:55 AM
87Toy4x4 Offline
whats wrong w/ sky?
Re: rear disc conversion [Re: 87Toy4x4] #671798 12/01/05 04:13 PM
Red_Chili Offline
Toyota Section Staffer
OK, I will speak for just myself. THIS IS MY OPINION ONLY, BASED ON OBSERVATION. YMMV.
Almost everything Sky sells was invented elsewhere with much care, then shamelessly copied (at somewhat lesser quality to undercut price, sometimes it matters, sometimes it does not). I choose not to support such a thing.
Price is not everything. And this is coming from a major cheapskate.
-Bill
Re: rear disc conversion [Re: Red_Chili] #671799 12/01/05 06:30 PM
DirtyHarry Offline
Toyota Moderator
Exactly. I have friends in this industry who are very talented and work hard designing new parts because they LOVE what they do. Then someone comes along and copies the design and makes it out of cheaper material and undercuts the price. Budbuilt's website puts it best: "We are striving to produce parts that fill a need in the Toyota community without just copying others products. Life is too short to make the same parts that others do! There is lots more that needs to be produced, including some small, helpful parts that make things work better. "
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6406 MB (Peak: 0.7606 MB) Data Comp: Off Server Time: 2026-07-16 11:54:22 UTC
