Staying in control #672146 12/01/05 01:34 AM
tech30528 Offline OP
So there you are out on the trail with wet, muddy boots, trying to start on a slippery slope, but there are three pedals, and you only have two feet. So here are a couple on cheap and easy cool tricks:
Go to your local dollar store or office supply, and get a card of flat head thumb tacks. Take off the brake and clutch pedal pads, and stick the tacks thru from the back. The points should just barely stick thru, just enough to hold the soles of your boots enough to keep from slipping. I put one in the middle, and six around it. Works great.
Now go to your local bicycle store, and get a hand brake lever for a BMX bike. Make sure you get the one for the rear brake so the cable is long enough. Now attach the lever to your shifter with the lever sticking straight up and facing forward. Attach the cable to the bottom of the dash with a line clamp, and the cable to the ball on the end of the throttle cable where it comes thru the throttle lever at the top. One of those little ball chains with the pocket clasp works great. You may have one as a key chain. Or you can try your local accessory shop. We have a place here that installs Line-X, tints windows, and installs aftermarket cruise controls. They have lots of left over parts from the installation kits. And just like that, you have a hand throttle.
The reason I say a BMX lever is because they are small, and come in all kinds of cool anodized colors.
Re: Staying in control [Re: tech30528] #672147 12/01/05 02:29 AM
CraShYota Offline
or just use an automatic.. <img src="/forums/images/graemlins/evil.gif" alt="" />
Welding and Fabrication Engineer
2003 taco V6 ext cab sr5
1988 Toyota Pickup V6(totaled)
Re: Staying in control [Re: CraShYota] #672148 12/01/05 02:36 AM
Rauch_Off_Road Offline
Uh dude only chicks drive autos and are proud of it. <img src="/forums/images/graemlins/nana.gif" alt="" />
(aka suprathepeg, aka Sean)
Re: Staying in control [Re: Rauch_Off_Road] #672149 12/01/05 03:53 AM
kewlynx Offline
Uh dude, you forget people with bad knees or hand controls...
**ubi apis- ibi salus**
Re: Staying in control [Re: tech30528] #672150 12/01/05 04:02 AM
abnormaltoy Offline
Ditch the rubber covers and weld spots on your pedal faces or drill and tap the pedals for some Phillips head machine screws.
Mark
Re: Staying in control [Re: abnormaltoy] #672151 12/01/05 04:04 AM
kyle-22r Offline
ive never had a problem staying on the pedals. with my size 13 boot the odds are that if i put my right foot down it'll probably hit the brake <img src="/forums/images/graemlins/lol.gif" alt="" />
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Staying in control [Re: tech30528] #672152 12/01/05 04:05 AM
CapnCrunch Offline
Getting back on topic: I did a similar thing for a hand-throttle. Overseas, my rig is equipped with a dial-type throttle but here in the states they aren't, however, they're still outfitted with the associated brackets. I picked up an old-style Shimano gear-shift lever (the non-clicking kind) for a ten-speed and rigged it to the built-in hook-ups. Works like a champ.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: Staying in control [Re: kewlynx] #672153 12/01/05 04:15 AM
Ah I'm just tryin to stir up some shat no harm ment.
Re: Staying in control [Re: Rauch_Off_Road] #672154 12/01/05 04:33 AM
G
Greg_Canada Offline
I have problems sticking to the pedals when my shoes are packed with snow or mud!! (or are really wet!)
89 4Runner
Re: Staying in control [Re: Greg_Canada] #672155 12/01/05 04:53 AM
kewlynx Offline
THIS STUFF works great with bunny boots. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.005s) Memory: 0.6377 MB (Peak: 0.7624 MB) Data Comp: Off Server Time: 2026-07-09 16:55:06 UTC
