ignition coil #673552 12/04/05 11:20 AM
L
lu0902 Offline OP
I need to replace my ignition coil. Which one of these would you recommend. The coils found on www.summitracing.com or http://www.jcwhitney.com/autoparts/...0000219038/Pr-p_CATENTRY_ID:100000219038 or should I go with the OEM coil. I was going to go with OEM, but the first two seem like an upgrade. A second opinion would be highlly appreciated. Acoording to the repair manual, these are the OEM ignition coil specs:
oil filled
primary resistance 1.2 ohms
secondary resistance 17.0 K-ohms
external resistor resistance 1.35 ohms
1987 DODGE RAIDER 4X4, 2.6 LITTER, 5 SPEED MANUAL MODS+PARTS:
Re: ignition coil [Re: lu0902] #673553 12/04/05 03:44 PM
BobShaw Offline
I used an Accell(sp) from Summit. Be carefull of the more powerfull MSD coils. Too powerfull a coil and it blows holes in your spark plug wires. You could also try their copper electrode dizy cap and roter.
I recommend an upgrade but be carefull not to go too far.
Bob Shaw
Re: ignition coil [Re: BobShaw] #673554 12/04/05 10:21 PM
I'm running an Accel Superstock in nifty yellow in the turbo Raider 2.6, and it's plenty. I mistrust jcwhitneyjunk.
Re: ignition coil [Re: fasteddy] #673555 12/04/05 10:36 PM
Monty Offline
I also use the Superstock its been there for about 4 years now, with no problems at all.
Stay away from jc unless its brand name, you get what you pay for IMO
1989 Raider V6/MT
2005 Jeep Liberty CRD Turbo Diesel
Re: ignition coil [Re: Monty] #673556 12/05/05 05:16 PM
dadrab Offline
I purchased a Superstock and it was crap right out of the box. I chased imaginary grimlins for weeks only to discover later the brand new coil was bad. No refund either which served to further piss me off.
...but I digress. I put on an MSD Blaster II and have been very pleased.
with awesome audio.
Re: ignition coil [Re: dadrab] #673557 12/05/05 05:30 PM
lordtrunks Offline
Make sure your distriburtor isn't on its way out one guy here in az had his fail on the trail it was shorting back and burned up his coil(oil leaking everywhere from coil) after replacing the coil and balist we then found it was his dizzy. a smoking balist is also a good sign of this. <img src="/forums/images/graemlins/scared.gif" alt="" />
89 2 dr turbo diesel
89/88 "Backwoods sas"
PHP: 7.4.33 Page Time: 0.023s Queries: 15 (0.017s) Memory: 0.6132 MB (Peak: 0.6835 MB) Data Comp: Off Server Time: 2026-11-18 03:32:03 UTC
