limited slip options #673698 12/05/05 12:16 AM
hdrisc Offline OP
What options are out there for a V6 3rd? I know I don't want an air or electric locker (something automatic?) The diff will be going into a 4cyl. housing, so are any modifications needed? Do I also need to swap the front diff?
The gears (4.10) are then same between trucks.
Re: limited slip options [Re: hdrisc] #673699 12/05/05 02:24 AM
kyle-22r Offline
i know you can get a true trac LSD and i'm pretty sure auburn makes a posi for the V6 3rd. you can put a V6 3rds in a 4cyl housing no problem. i had to clearance the ring gear notch on the housing a tiny bit(i think it was a factory screwup, as the flange on the axle is a double thickness, the top layer was notched but not the inner layer).
'91 4x4 shortbed
22R-E, W56, the dd!
Re: limited slip options [Re: hdrisc] #673700 12/05/05 05:19 AM
benmlee Offline
Downeyoff-road.com sells a limited slip diff. I believe these are the OEM ones with semi-metalic clutch plates. They are suppose to last a long time, and give good performance.
Re: limited slip options [Re: benmlee] #673701 12/05/05 05:31 AM
bkg Offline
I love the TrueTrac - great unit. I've owned two - one that was in three different vehicles, and one in my 96.
Brian K. Gallus
Re: limited slip options [Re: bkg] #673702 12/05/05 07:00 AM
A
allochris Offline
i just bought a 87 supra lsd today for a hundred bucks to swap in my rear v6 3rd! Will right back on how easy the swap will be...
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: limited slip options [Re: allochris] #673703 12/05/05 10:32 PM
Rauch_Off_Road Offline
Hey allochris what is the back to MTL in you location mean???
(aka suprathepeg, aka Sean)
Re: limited slip options [Re: Rauch_Off_Road] #673704 12/06/05 01:25 AM
A
allochris Offline
Just the fact that i'm moving all the time almost every 4 months, currently in MTL. Been living in many different cities the last few years. (mtl/toronto/brantford/waterloo/golden/rossland/ squamish/whistler/nelson/kelowna/.../u get the idea...
That's also why i've already log over 40,000km in 14 months of truck ownership! <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: limited slip options [Re: allochris] #673705 12/07/05 09:09 PM
dcg9381 Offline
Have you considered a mechanical locker - something like the Aussie locker? Pretty easy to install and cheaper than a LSD.
22REturbo.net
1988 4Runner
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6245 MB (Peak: 0.7067 MB) Data Comp: Off Server Time: 2026-11-19 23:55:41 UTC
