Power brake vacuum hose #673752 12/05/05 03:08 AM
Don_W Offline OP
Master,
In my feeble attempt at replacing the vacuum line to my power brake on my 1989 Trooper 2.6L 5 Speed, I discovered a "check valve" in the hose. The Cro-Magnons at the Auto Parts place were mystified, leaving me with no convenient replacement. What is the function of this valve, and is it essential?
Don
1989 Trooper II 2.6L
222,222
Re: Power brake vacuum hose [Re: Don_W] #673753 12/05/05 03:43 AM
randii Offline
Somewhere between essential and nice-to-have -- I recommend it. Without it, your power-assisted brakes go away immediately if the engine dies.... with a functioning check valve in place, you'll get a couple good shots of assisted braking before the pedal gets unhappy. The valve itself hardly ever faills - I recommend recycling your existing valve by splicing it into the new hose. You can test your valve by sucking/blowing on each end. The vacuum booster side should blow freely, but not permit you to suck, and the engine side should suck and blow freely. There's an easy joke in there about how hard I suck. <img src="/forums/images/graemlins/pfft.gif" alt="" />
If you do not have that valve, you should be able to snag one from any u-pull-it junkyard.
Randii
Randy Burleson
4x4Wire Managing Editor Emeritus
Mongrel Isuzu Amigo
Re: Power brake vacuum hose [Re: Don_W] #673754 12/05/05 10:21 AM
Don_W Offline OP
Master,
I am trying to get rid of any 16 year old hose. Is there someone who can sell me a new hose?
Don
222,222
Re: Power brake vacuum hose [Re: Don_W] #673755 12/05/05 04:59 PM
mlclark Offline
Isuzu Moderator
I bet Isuzu has a hose for you.
Call St. Charles. www.stcharlesauto.com and ask for Merlin.
Michael
Re: Power brake vacuum hose [Re: Don_W] #673756 12/06/05 01:53 AM
litnin Offline
Send Jerry Lemond a note a jlemond@bellsouth.net
He's got the hoses in stock and will probably sell it to you
cheaper than anyone else. The hoses he has are factory hoses.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: Power brake vacuum hose [Re: Don_W] #673757 12/07/05 03:29 AM
This should be a 1/2 inch neoprene vac hose, and the booster check valve is standard Chevy (or GM) and rarely fails. Lots O' GM influance on those great old Zus.
Rare for that hose to fail (but possible), check for tight valve adjustment.
Re: Power brake vacuum hose #673758 12/08/05 01:46 AM
Don_W Offline OP
It's a 16 year old hose, and showing cracks around the ends. The checkvalves still holds, but it's time to refresh.. Thanks for the GM tip
Don
222,222
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6154 MB (Peak: 0.6938 MB) Data Comp: Off Server Time: 2026-11-16 01:26:52 UTC
