High RPM missing
#674012
12/06/05 01:41 AM
O-k...looking for some suggestions here. On the way home today I was cruising on the freeway when the ole monty started to miss. I slowed down and it runs fine untill about 2500-3000 rpm when it starts to miss. It only does it in 4th and 5th gear. I pulled the plugs to discover that #1 and #4 cylinder plugs had a "crust" on them. The other plugs looked fine. I checked the wires and all the connections on the coil. Everything checked out fine... What could cause this? <img src="/forums/images/graemlins/confused.gif" alt="" />
02 Ford F-250 4X4 PSD...zero body damage 67 Weimann 18' Jet boat...zero body damage except for the trailer drags on the ground from time to time
Re: High RPM missing
[Re: Roll_me_over]
#674013
12/06/05 07:30 AM
when you say crust - describe it - what color?
Show me the muddy. . . .
[Re: Roll_me_over]
#674014
12/06/05 05:00 PM
what did the 2 and 3 plug look like?
[Re: LRJ4x4]
#674015
12/06/05 05:11 PM
89 2 dr turbo diesel 89/88 "Backwoods sas"
[Re: LRJ4x4]
#674016
12/06/05 09:57 PM
when you say crust - describe it - what color? It was like a brownish color. And I'm not saying like a fine crust. It was pretty thick. Like between 1/16 and 1/8 of an inch for lack of a better way to describe it... what did the 2 and 3 plug look like? they had the normal light brownish look on the electrode insulator...
[Re: Roll_me_over]
#674017
12/06/05 11:35 PM
I assume your using all the same type and heat range of plugs <img src="/forums/images/graemlins/smile.gif" alt="" /> Anyways just change them out with some factory plugs NKG's and see what happens. Don't waste your $$$ on any of those fancy aftermarket ones.
The two inside plugs burn different than the outside due to the design of the intake manifold. How many miles on these plugs?
[Re: LRJ4x4]
#674018
12/07/05 12:52 AM
And what had the gap opened up to? My money is on .050.
Are the deposits dry crusty, or oily crusty? You might suspect a water leak at the base of the carb, fender side.
[Re: fasteddy]
#674019
12/07/05 07:00 AM
plugs have maybe 10-15k on them and the gap was still at the correct setting. The crust was dry... As far as the missing, i changed the coil and the problem is solved...but the plugs have me baffled....
[Re: Roll_me_over]
#674020
12/08/05 05:12 PM
Check all the head bolts for tightness. Pressure test the radiator and listen at the carb for the leak.
[Re: fasteddy]
#674021
12/09/05 06:19 AM
so a coolant leak may cause the plugs to build up deposits...hmmm...that could be it considering that small hose from the carb to the intake broke spewing coolant everywhere the other day...
