Spindle Bearings #674063 12/06/05 03:09 AM
TyYota Offline OP
Got a price for Spindle bearings today from the dealer - $341 (CDN) for the pair!!!! WHAT!!! Dealer says toyota changed the design from a Brass bushing to a Roller bearing and thrust washer.
So either where do I find them cheaper? A LOT CHEAPER??? oR can I find the old style bushing? My truck originally came with ADD hubs, so that expains why their worn out, but I've got Manual hubs now so I can handle the reduced life of the bushing if they're available.
I found this article http://www.yotatech.com/~corey/tech/jimrockford_spindle/jimrockford.htm on replacing toyota spindle bearings. It looks like the spindle and the steering knuckle are one piece (I didn't know that), does the steering knuckle have to be removed from the truck, or can this be done on the truck.
Any more advise?
Tyler
'92 Toyota, 4x4, 22RE, winch, locker, 4.88's, 33's, 2" Body Lift.
Re: Spindle Bearings [Re: TyYota] #674064 12/06/05 03:28 AM
OOP'S Offline
Well considering it looks like you have to use a press for the install. I would say yes they have to come off!!!! Not that hard to remove them!!!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Spindle Bearings [Re: OOP'S] #674065 12/06/05 04:05 AM
willzrunna96 Offline
there are still the regular brass bushings but they redesigned the for cold climate trucks to use needle bearings so they dont moan when its cold. i priced them out and the inner was 34 and outer was 20
Re: Spindle Bearings [Re: willzrunna96] #674066 12/06/05 03:59 PM
Red_Chili Offline
Toyota Section Staffer
With locking hubs the old style brass bushings will work just dandy. Use a press, not a hammer - they distort easily.
-Bill
Re: Spindle Bearings [Re: Red_Chili] #674067 12/06/05 05:40 PM
TyYota Offline OP
Where can I find bushings? Dealer says the bearings have superseded the old bushings.
Re: Spindle Bearings [Re: willzrunna96] #674068 12/07/05 04:43 AM
Hey all! Not trying to redirect the subject, but I notice that groan with the temp. gets down into the teens. Only lasts a very short distance. Serious or just annoying?
Thanks y'all...sorry for the off topic, but first time I'd heard anyone else mention this.
Re: Spindle Bearings #674069 12/07/05 04:26 PM
Red_Chili Offline
Annoying. The spindle is oscillating due to the grease being extremely stiff/missing. I suppose you could be galling the bronze but I doubt it.
Personally, I would defeat the ADD and use locking hubs to fix the problem.
-Bill
Re: Spindle Bearings [Re: TyYota] #674070 12/07/05 04:27 PM
Red_Chili Offline
Sorry, I've never gone down that road (see reply above). You could check the boneyard. What leads you to believe you need to replace them (I assume you've measured clearances against the FSM specs)?
-Bill
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6214 MB (Peak: 0.7155 MB) Data Comp: Off Server Time: 2026-07-15 00:21:27 UTC
