high ldle(posting for a friend) #674090 12/06/05 04:26 AM
TX4wl Offline OP
I have an 88 jeep cherokee that has a mind of it's own.It's idle when started pegs at three grand.If i unplug the tps,or vacum to the map idle drops to normal.when i plug the map vacum back up it pegs at three grand.If i plug the tps back up it idles at 1500 rpm.I replaced the tps about a month ago and thought it was fixed.It's back now.Have already tried ect,map.no change.ANY IDEAS?
__________________
Re: high ldle(posting for a friend) [Re: TX4wl] #674091 12/06/05 05:00 AM
Tune-up, check for vacume leaks.... ETC...
What is the map voltage at idle? What is the TPS voltage at idle?
Re: high ldle(posting for a friend) #674092 12/06/05 05:17 AM
TX4wl Offline OP
PM'ed ya!
Re: high ldle(posting for a friend) [Re: TX4wl] #674093 12/06/05 11:51 PM
cuervo25 Offline
i dont know what tx sent you, but most of the time it is a sticking idle control sensor. all you need to do is remove it and give it a good dousing of carb cleaner, and scrub it with an old toothbrush. also spray out the hole it goes into
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5981 MB (Peak: 0.6550 MB) Data Comp: Off Server Time: 2026-05-29 19:50:41 UTC
