Newbie Looking For First Truck #674408 12/07/05 04:50 AM
kxtoy Offline OP
All, I've been lurking for awhile trying to make up my mind whether or not to buy. It's made up <img src="/forums/images/graemlins/smile.gif" alt="" /> and just called about an '85 SR5 truck. Guy was asking $2500. Here's the details:
320k miles
Original motor 22RE (at least that's what he thought)
new timing chain
replaced front diff (was making a racket)
bed has some rust
frame supposedly solid
runs good
no signifcant leaks
doesn't smoke
cold a/c
Now I know these trucks are great, but this seems a bit high for all the miles and a rusty bed. I did read the post on how these hold there values. What do you guys think? The guy knows he's got the good stuff.
Chris
Re: Newbie Looking For First Truck [Re: kxtoy] #674409 12/07/05 05:44 AM
Talon84X4 Offline
Dooooo it dooooo it dooooo it! I would, because 85's are rare around here
'84 PU low & slow
Central Valley Crawlers
Re: Newbie Looking For First Truck [Re: Talon84X4] #674410 12/07/05 06:11 AM
kyle-22r Offline
320k is a little high in the mileage department, but if the engine runs fine you'll be OK. as for the rust, you'd think it came from the factory on those things <img src="/forums/images/graemlins/lol.gif" alt="" />
cold A/C is a definite plus, and add to the fact that a lot of idiots think they have a goldmine if they've got an '85, $2500 isn't too bad. see if you can haggle a little though.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Newbie Looking For First Truck [Re: kyle-22r] #674411 12/07/05 06:56 AM
4WD22R Offline
BUY IT!!! or at least tell me where it is <img src="/forums/images/graemlins/wink.gif" alt="" />....that's what I wanted to find. And if the engine does crap out on you they are not too hard to replace at all.
This is truly a rare one tho(at least around my parts) fuel injected' 85 with cold AC!!! most desireable of all, could only be better if it was a 4Runner!! <img src="/forums/images/graemlins/lol.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Newbie Looking For First Truck [Re: kxtoy] #674412 12/07/05 03:52 PM
kxtoy Offline OP
Sounds like I should at least pay it a visit. I think I will.
Re: Newbie Looking For First Truck [Re: kxtoy] #674413 12/07/05 04:09 PM
Rauch_Off_Road Offline
If there is rust coverage on the frame then do a real real thourough job of rust checking. cram you little fingers between the frame and the gas tank to see if there are holes. Then take a hammer and smack all over the frame especially around the rear wheels. If the metal deforms then I would let it go. better to have the base rig your happy with then one that you curse cause of the frame rust. Good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />.
(aka suprathepeg, aka Sean)
Re: Newbie Looking For First Truck [Re: Rauch_Off_Road] #674414 12/07/05 08:02 PM
kxtoy Offline OP
Thanks for the input so far.
I'm going to look at this truck, but let me add a little more input. I haven't done a ton of 4 wheeling, but what I have done I have really enjoyed. I just finished restoring a 77 Bronco (mostly body work and replaced the usual maintenance items - turned out sweet, to sweet to tear up). I have been to Wheeling In The Country off road park in Middle Tennessee a couple of times in the Bronco and had a blast. I'm not much of a mechanic, but I am willing to learn. I am looking for a Toyota as a reliable 4 wheeler (goes without saying). I want to get my feet wet with as little investment as possible. I was thinking stock truck or 4 runner, put some 31s on and maybe limited slip. Play with that for a while and if it really sticks, modify from there. If it doesn't stick, I want to be able to get out and not lose my shirt. If this truck is in reasonably good shape (frame and drive train) and I could get it for around $2k, do you think I could get out if I wanted to without losing my shirt (that wouldn't be a pretty site)?
TIA
Chris
Re: Newbie Looking For First Truck [Re: kxtoy] #674415 12/07/05 09:58 PM
kyle-22r Offline
more than likely, they hold their resale value very well, especially if it has EFI.
they're a good first 4x4 to learn on, i learned just about everything i know about being a mechanic on my toyota. most of the parts are very forgiving, especially the engines.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Newbie Looking For First Truck [Re: kyle-22r] #674416 12/07/05 10:40 PM
Seattlegti Offline
I've found 80's Toyota trucks not only hold thier value but appear to become more valuable as time goes by.
I saw the 82 long bed I used to drive back in high school(1989) over thanksgiving weekend. Asking price was $2,000 with almost 200,000 more miles on it that when I owned it.
Current truck is and 88 V6 4runner I bought for 3K, worth more now even without all the ARB/OME stuff.
Re: Newbie Looking For First Truck [Re: kxtoy] #674417 12/10/05 01:36 AM
tech30528 Offline
Buy it. I bought my '85 EFI 8 years ago for $1000 with bad rings. The only thing better would be an extended cab or a 4Runner. I had to put a new bed on it (new from Toyota, $1300), worth every penny. I've been offered $6000 for it, and turned it down. I'm 36, I'm driving it until I'm at least 50.
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.006s) Memory: 0.6383 MB (Peak: 0.7628 MB) Data Comp: Off Server Time: 2026-06-17 06:35:51 UTC
