tiny plug wires. oem? #674444 12/07/05 05:58 AM
BAZ Offline OP
I was looking under my hood the other day and noticed that my plug wires were tiny! I know that the wires the previous owner installed were probably some crappy aftermarket cheapies but wow! Is this the correct gauge?
I have always been partial to OEM or NGK guy when it came to plug wires and my crx's/BMW. Will changing out my plug wires make a noticeable difference in the 22r-e at all?
1994 Toyota X-Cab 4WD 22R-E 5 speed.
Re: tiny plug wires. oem? [Re: BAZ] #674445 12/07/05 06:15 AM
kyle-22r Offline
most likely not unless you're one of those people that think taking sugar pills will cure your sickness! <img src="/forums/images/graemlins/lol.gif" alt="" />
measure the resistance with an ohmmeter, if they are within spec they'll be fine.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: tiny plug wires. oem? [Re: kyle-22r] #674446 12/07/05 06:24 AM
BAZ Offline OP
Ha.
Well I figured as much but it really threw me off when i saw these tiny wires coming from my cap. I figured if it Toyota put them on there they must be on there for a reason. Just never seen anything that small before, even on tiny 1.5/1.6 d-series honda motors. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: tiny plug wires. oem? [Re: BAZ] #674447 12/07/05 06:32 AM
TheBandit Offline
Are they OEM wires? If so they will be labeled Toyota and have numbers indicating cylinders 1-4.
EDIT My OEMs say Sumitomo. I was wrong when I said they would be labelled Toyota.
I am very happy with the quality of construction of my OEM wires. They are about the same size as the 8mm Accell wires I had on the truck previously.
[color:"darkgreen"]1986 4Runner - 4" IFS - 63" Chevys - 33" ATs - 5.29s - Rear Detroit
Sliders - Kayline - Rebuilt 22RE - On Board Air AND Factory AC
www.xtremefabricator.com[/color]
Re: tiny plug wires. oem? [Re: BAZ] #674448 12/07/05 06:45 AM
Coyotekid Offline
Well, I've got tiny-OEM wires on mine (3.0).
Not sure if the 22Rxx's are the same though...
~~~The more People I meet, the more I like My Dog..~~~
-96' Tacoma 3.4 4x4 5 Speed, Trueflow intake+Deckplate, 2.5 inch Magnaflow Cat-back,OME 881's, and some extra-leaves in the rear..
-68' Chevelle Malibu..Stage one of Restoration: *Collecting funds* <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: tiny plug wires. oem? [Re: Coyotekid] #674449 12/07/05 07:04 AM
BAZ Offline OP
Just checked my wires.
They're "yazaki" brand. I'm assuming they're some el cheapo OEM replacments. I know its not like I'll see some huge performance gain if I switch them out but maybe It'll idle a bit smoother with some NGK oem replacements. The wires are relatively new I think.
Re: tiny plug wires. oem? [Re: BAZ] #674450 12/07/05 07:42 AM
kyle-22r Offline
my wires are black and have some japanese name on them, i'd bet they're OEM. i've never seen any electrical components(aside from maybe an ECU) in my trucks that ever said toyota.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: tiny plug wires. oem? [Re: BAZ] #674451 12/07/05 07:56 AM
stock87 Offline
Nope, Yazaki is an OEM manufacturer. They all seem to be Yazaki or Sunimoto that I've seen.
My original Yazaki set lasted 17 years, so I wouldn't be too worried.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: tiny plug wires. oem? [Re: BAZ] #674452 12/07/05 09:12 AM
3
355Camaro Offline
I took the stock ones off and upgraded to the accel 8MM wires, I like crimping and figured why not, upgrading the cap and plugs. Was only $30 for the box of uncrimped at advanced auto
2000 Audi TT 1.8Turbo Quattro
1988 Chevy Camaro - 100% Built + for sale!
Re: tiny plug wires. oem? [Re: BAZ] #674453 12/07/05 09:18 AM
Brian894X4 Offline
Yep, they likely are stock...but only for your model year. Toyota used a slightly different igntion system for '94 model 22REs. And I see yours is a '94. I'm not sure what the other differences were, but one of them was smaller/thinner plug wires and I believe a different type of connector to the cap.
If I recall correctly, and I could be wrong, this system was prone to problems and Toyota reverted back to the old style ignition for the '95 model year, before switching over to Tacoma production.
I've also heard that '94-95 models seem to have the timing chain failure problem happen a little earlier than prior models. I've heard of one '94 chain needing replacement at just over 60K miles and another at well under 100K. So, keep a close eye on yours, unless the chain/guides have already been changed.
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6391 MB (Peak: 0.7623 MB) Data Comp: Off Server Time: 2026-10-24 02:34:33 UTC
