Has anyone done a 2" BL on a 3rd gen truck? #674689 12/07/05 08:56 PM
Rauch_Off_Road Offline OP
This is the next step on my project "Black Beauty" and I'm just wanting to be ready for the install.
Did you guys have to do anything with the steering, brake lines or the shifter?
(aka suprathepeg, aka Sean)
Re: Has anyone done a 2" BL on a 3rd gen truck? [Re: Rauch_Off_Road] #674690 12/07/05 09:33 PM
TyYota Offline
Made my own 2" body lift out of UHMW poly.
Went smoothly but I had to grind the firewall around the steering shaft, but didn't have to lenghten it.
Shifter had to be bent (actually ended up cutting and rewelding) to make shifting into 2nd, 4th, and reverse. I also had to remove one layer of the 3 layers of shifter boots.
Brake lines and fuel filler were fine.
After a couple months I ended up lowering my rad with some sheet metal brackets.
Tyler
'92 Toyota, 4x4, 22RE, winch, locker, 4.88's, 33's, 2" Body Lift.
Re: Has anyone done a 2" BL on a 3rd gen truck? [Re: Rauch_Off_Road] #674691 12/07/05 09:35 PM
4Crawler Offline
Steering and shifter yes, brake lines just sort of uncoil:
- http://www.4crawler.com/4x4/ForSale/Docs/BodyLift_HowTo.shtml
Re: Has anyone done a 2" BL on a 3rd gen truck? [Re: TyYota] #674692 12/08/05 02:03 AM
P
Poor A$$ Stock '93 Offline
Went smoothly but I had to grind the firewall around the steering shaft, but didn't have to lengthen it.
Shifter had to be bent (actually ended up cutting and re-welding) to make shifting into 2nd, 4th, and reverse. I also had to remove one layer of the 3 layers of shifter boots.
Tyler
I also built my own out of 2.75"x2" UHMW poly. 2.75" dia. was the max I could fit. As for everything else: Steering shaft had enough slip. No grinding or anything else needed. Had to drop the rad and the brake hard line that mounts to the passenger side firewall 2". That is all. Went like a piece of cake. Oh almost forgot. Shifter boots want to pull the truck out of 2nd gear so I had to make a new boot. I just turned the inner black rubber one upside down and put it back in and you will need a new upper. Gets very hot/cold in the cab (depending on weather) as well as noisy/dirty with out the boot. This was on a '93 V6.
North Caribou Offroad Adventurers Society
www.offroad.bc.ca
Re: Has anyone done a 2" BL on a 3rd gen truck? [Re: Poor A$$ Stock '93] #674693 12/09/05 08:35 PM
Does anyone have pics of the shifter area like the grinding or boot modifications?
Re: Has anyone done a 2" BL on a 3rd gen truck? [Re: Rauch_Off_Road] #674694 12/10/05 06:12 PM
CJM Offline
I just did one in the shop ....
as above , and I just moved the shifter boot&retainer back ~1/2" ...... boot/shifter problem solved .
83 Trekker SR5
NEW Trekker forum
Re: Has anyone done a 2" BL on a 3rd gen truck? [Re: Rauch_Off_Road] #674695 12/10/05 06:23 PM
4Crawler Offline
Feel free to look on my body lift installation notes page, you'll find all sorts of pictures and tips:
http://www.4crawler.com/4x4/ForSale/Docs/BodyLift_HowTo.shtml#ManualTranny
One option:
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6208 MB (Peak: 0.7111 MB) Data Comp: Off Server Time: 2026-07-14 03:51:12 UTC
