Freeze plug removal #674702 12/07/05 09:09 PM
get2now Offline OP
Did a search and can't find it anywhere. How do you remove freeze plugs?
Thanks for any help.
Gary
Re: Freeze plug removal [Re: get2now] #674703 12/07/05 11:49 PM
BigJim Offline
You take a punch and a BFH put the punch on one side or the other of the plug and knock the $hit out of it... It should getsideways in the hole and the "other side" should protrude. Then you get hold of the side sticking out and remove it.. If by chance it jumps into the block you start fishing.. I have been known to leave one inside an engine from time to time. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: Freeze plug removal [Re: BigJim] #674704 12/08/05 03:05 AM
get2now Offline OP
Thank you, Thank you, Thank you....
I love using BFH's.... <img src="/forums/images/graemlins/notooth.gif" alt="" />
Gary
Re: Freeze plug removal [Re: get2now] #674705 12/09/05 04:00 AM
atavuss Offline
an easy way to get the plug out once you have knocked it sideways is to grab it with water pump pliers (aka groove joint pliers, adjustable pliers) and leverage the plug out. how are you going to knock the new plug in? there are special tools made to drive the plug into the block.
04 4x4 Double Cab Tacoma v6 TRD, all stock
77 Jeep CJ7, 304 v8, 33x12.50x15 bfg, 4.10 gears, 44 rear end, ford bronco low range gear mod, warn 6k winch, rubicon tested
1969 M274a5 Military Mechanical Mule
46 Bantam Civilian trailer
Re: Freeze plug removal [Re: atavuss] #674706 12/11/05 09:39 PM
get2now Offline OP
Well, I got them out by tapping one side of the plug then when it was sideways I grabbed it with a pair of needle nose vise grips. It came right out. Installing the new ones I just used a LFH (little **** hammer) and a socket to fit inside the plug. It worked fine and didn't distort it at all.
Thanks,
G
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6066 MB (Peak: 0.6710 MB) Data Comp: Off Server Time: 2026-05-29 23:44:32 UTC
