Re: Another SAS started(with pics)
[Re: spacecab90]
#674841
02/09/06 05:33 AM
have you thought about losing the body lift?
88 Troop - Posing yard art
[Re: paulevans76]
#674842
02/09/06 07:16 AM
With the way the frame extension is mounted, I'm guessing that some body lift will be necessary to keep those forward facing square tubes from hitting anything. That is a lot of lift, however. Looks dangerous without a full width axle. Before you go and remove a bunch more leafs, have you considered trying spring under?
Sammy
95.5 Rodeo, automatic, 3.2 SOHC, D44 front and rear, 4.88's, 33" muds
[Re: Sammy]
#674843
02/10/06 12:53 AM
I would get rid of the body lift and cut whatever is in the way. You can fabricate a new front radiator support as your's is probably rusted out anyway.
CHRIS 98 Amigo, 92 Pup
[Re: CPOM]
#674844
02/18/06 01:33 AM
Today i got rid of the body lift... I had to do some cutting and beating on the radiator support to make room for the new "frame",but everthing turned out well i think. Took a few leaves out of the spring packs.... and made a really obnoxious differential cover, from a new dana cover, and spent a couple hours beating quarter inch by 1.5 inch strap with a sledge hammer, to help protect the ring gear. I think it turned out well, and it displays some pride for my team, even though they did really horrible this past year hahaha... ![[Linked Image]](http://i27.photobucket.com/albums/c175/spacecab90/DSCF0287.jpg)
1990 Isuzu Spacecab, SAS 95% done
'06 Nissan Sentra SE-R Spec V
[Re: spacecab90]
#674845
02/18/06 03:42 AM
:clap: :clap: :clap:
much better.....now it's starting to look like something. <img src="/forums/images/graemlins/wink.gif" alt="" />
your diff is almost done............just waiting on an inner pinion bearing <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
'93 RS 3.2L - DD/trail build '97 7.3L Powerstroke - tow rig '71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build Owner: http://www.INDEPENDENT4x.comm-f 9am-6pm EST. 804-550-0480
[Re: spacecab90]
#674846
02/18/06 03:44 AM
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> Looks sweet!!!!! If I didnt need a new engine soon, I'd be next in line for doing a SAS <img src="/forums/images/graemlins/smile.gif" alt="" /> Can you get some side shots? I want to see what those 37's look like <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: onebadtrooper]
#674847
02/18/06 04:53 AM
Looks good with the reciever and all the gussets in the front. And 10x better with no body lift. Have you tried flexing it up yet to see where it rubs?
[Re: spacecab90]
#674848
02/18/06 06:13 AM
<img src="/forums/images/graemlins/kewl.gif" alt="" /> Lookin good!!! Nice to see pick-up recieving a SAS
Craig
1986 Isuzu Trooper 2dr LWB 1999 Saturn SL
[Re: wb86]
#674849
02/18/06 09:29 AM
Damn, there's Green Bay fans everywhere -- even under a solid axle Rodeo in Virginia. Just as dedicated as Raider fans, but with midwest innocence. Yes, I grew up in Wisconsin.
Good job on all the progress. Throw some more photos up when you get a chance.
Sammy
[Re: Sammy]
#674850
02/19/06 12:00 AM
Well here are a few more pics.... Measuring for shock length, and tire clearance.. I thought there would be a lot more rubbing on the fender. My only concern, is the tires are rubbing on the springs.. Nothing a longer steering stop can't take care of. Side shot, stuffed up in there about as much as it will go. There is roughly 5 inches between the frame rail and the top of the spring plate. I will have to cut just a little bit of sheet metal, but not nearly as much as i was suspecting.. TO DO: bump stops Brakes lines Drag Link Front Diff Install shock mounts SPring over rear making some sort of sway bar out of the old torsion bar and of course reengineering everything after its done to work properly. Peace Joel
