Pinion nut torque #675186 12/08/05 10:38 PM
TyYota Offline OP
What should I torque my rear pinion nut to? Manual says 145, Roger Brown says 90, but shouldn't I be tourqing it a little at a time till I get the right bearing preload? I'm doing my pinion seal right now. Gears were installed professionally 1 year ago. The pinion nut was staked but just tightened, maybe 10 ftlbs.
What do you say?
Tyler
'92 Toyota, 4x4, 22RE, winch, locker, 4.88's, 33's, 2" Body Lift.
Re: Pinion nut torque [Re: TyYota] #675187 12/09/05 12:45 AM
ZUK Offline
If there's a solid collar in there then 150~200 ft/lb will be ok.
If it has the typical crush sleeve then just keep snuggin it until the pinion drag feels right. Good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
mostly stock
Re: Pinion nut torque [Re: ZUK] #675188 12/09/05 01:31 AM
4Crawler Offline
I generaly do no more than about 90 ft.lbs. on mine.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5926 MB (Peak: 0.6459 MB) Data Comp: Off Server Time: 2026-07-14 05:33:40 UTC
