Info on ECM needed.
#675760
12/10/05 07:52 PM
Hey all, after a year of PO773 I had shift solenoid E replaced. The Toyota tech said everything is functioning correctly, however my ECM is "going" so its having mis-communication with the solenoids, which in time will cause premature failure. The truck still throws PO773 even though that part is replaced. My question is about the ECM's function. Also, I have the part #(not with me at the moment), and was looking for suggestions for finding a used one. (new $1080.00). Thanks for any input. 95 t100 5vzfe A/T 4x4
Re: Info on ECM needed.
[Re: elnido]
#675761
12/11/05 12:36 AM
They come up on ebay once in a while for between $75-$150. Keep looking and make sure it is for the A/T. Car-parts has a bunch listed for around $300 and seems 2/95 mfg date on is different from 1/95 and before: parts Just noticed a 95 wiring manual you might be interested in on ebay now: 95 elect manual
1997 T-100 4X4 Xcab,Warn Hubs 02 Camry LE 2008 Yaris
Has anyone every had an ECM refurbished (R&R'ed)?
[Re: garym]
#675762
12/12/05 09:36 PM
(thanks gary)
I'm torn between gambling 150 for a used replacement or $300 on mine being refurbished.
Re: Has anyone every had an ECM refurbished (R&R'ed)?
[Re: elnido]
#675763
12/14/05 02:27 AM
It's not really an item that goes bad very often... Probably fine with a used one. Fwiw, I'm using a used one I got from Surlynkid (after frying mine trying to reprogram it myself... Oops <img src="/forums/images/graemlins/barf.gif" alt="" />)
4xGeek (Chris) '97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc... No longer stuck in SoCal!!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5999 MB (Peak: 0.6556 MB) Data Comp: Off Server Time: 2026-06-17 16:41:53 UTCValid HTML 5 and Valid CSS
