Towing Question #675890 12/11/05 03:56 AM
I have a 2001 4runner sr5 and going to trailer my boat from n.y. to s.c. about 700 miles. Boat and trailer is 4500lbs. I've done all the fluids on the truck and added a transmission cooler. Will the truck handle the drive or am I over doing it? Also While on the highway do I keep the O.D. disengaged.
Re: Towing Question #675891 12/11/05 04:42 AM
Coyotekid Offline
Do you have the 3.4, or the 2.7?
Automatic I take it...
I've towed 3000 lbs (ish) from Arkansas to California before with My 3.0. 5 speed, 4x4. That was gross-weight.
I just 4th geared it alot. mileage dropped a little, but it towed fine!
If you have the 3.4, I would say don't sweat it!
Well, do you have a tow-hitch? Or are you just connecting straight to your bumper?
-Dano- <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
~~~The more People I meet, the more I like My Dog..~~~
-96' Tacoma 3.4 4x4 5 Speed, Trueflow intake+Deckplate, 2.5 inch Magnaflow Cat-back,OME 881's, and some extra-leaves in the rear..
-68' Chevelle Malibu..Stage one of Restoration: *Collecting funds* <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Towing Question #675892 12/11/05 04:59 AM
dragr1 Offline
Since you have the tranny cooler, and IF you have a tow hitch and the 3.4 then yes you will be ok. You will most likely not want to run in overdrive unless it is rally flat ground though.
1985 Toyota 4Runner, dual e-lockers, exo and more
2007 Toyota Tacoma Crewcab TRD 4x4
2000 Suburban 2500 4x4
1991 Tiffin Allegro Class A MHome (Ole Krusty)
Re: Towing Question #675893 12/11/05 05:55 AM
Yes it is a 3.4L engine. thanks for the replies.
Re: Towing Question #675894 12/11/05 03:25 PM
Dandeman Offline
Toyota Moderator
As you mentioned, it is best when trailer towing to run with O/D off.. The transmission ECU is very aggressive about keeping the torque converter locked up when operating with O/D off to keep the heat down.. and is recommended by Toyota for trailer towing for this reason.
4th gear with the torque converer running in max torque multiply yields nearly the same gear ratio as 3rd gear with the torque converter locked.. The difference is the former generates tremendous amount of heat in the torque converter and the latter produces near zero in lock up state..
Read this for further explanation..
Re: Towing Question #675895 12/11/05 09:09 PM
E
esun127 Offline
You have trailer brakes I hope?
I've towed 3500 lbs up mountains to 5000 ft elevations starting at 0, so as long as your drive is relatively flat, you should be fine. Since your trailer weight is higher than your TV weight, definitely keep things slow.
Re: Towing Question [Re: esun127] #675896 12/12/05 02:12 PM
Yes my trailer has brakes, I had all 4 wheels drums, but the saltwater took care of that. I just installed frt brake only. My tow rate for the truck is 5000lbs. so no fuel in the boat tank which is 90gals. is a weight saving. gives me more room for some fresh NY bagels and bread smile smile lol. I hope I81 isn't that bad this time of year, otherwise its I95 all the way.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6124 MB (Peak: 0.7057 MB) Data Comp: Off Server Time: 2026-06-17 04:05:02 UTC
