Heavy Duty Clutch??? #675905 12/11/05 04:45 AM
O
OneStar Offline OP
My 89 Toyota pickup 22RE Deluxe has a 6' 6" Fisher Minute Mount plow on it (bought it that way). Used it for the first time yesterday. It plowed very well. But I need to get used to plowing with a standard trans (pain in the ass). From time to time I could smell something burning. My guess would be the clutch. Maybe I'm wrong and you guys can point me in the right direction. But if I'm right and it is the clutch, is there a heavy duty clutch or something out their that I can have installed? Which brand would you recommend and why?
Thanks.....
Re: Heavy Duty Clutch??? [Re: OneStar] #675906 12/11/05 04:55 AM
toy94x4 Offline
If you're riding the clutch a lot then that most likely is it. If you're plowing at slower speeds like in a parking lot and not on the highway, maybe try putting it in 4LO and benefit from that. Sorry, I don't have a suggestion for a heavy duty cluth, haven't had to do mine yet.
1994 P'up, 22RE, K&N, LCE exhaust sys (header, cat, muffler, 2.25" pipe), 1" RB seat lift, 1" RB body lift, 1.5" rear lift via shackles, Rancho 5000's, 33" Pro Comp M/T's, 4.88's w/ Aussie lockers front & back
Re: Heavy Duty Clutch??? [Re: toy94x4] #675907 12/11/05 05:01 AM
OOP'S Offline
Were you in low range in the T-Case, you should be?
I have had real good luck with a CenterForce I in my truck, been beating on it for seven years!!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Heavy Duty Clutch??? [Re: OOP'S] #675908 12/11/05 06:51 AM
O
OneStar Offline OP
I was not in 4LO. I honestly didn't think it would make a difference. I will definetly try it next time. I guess you learn something new every day.
Thanks.....
Re: Heavy Duty Clutch??? [Re: OneStar] #675909 12/11/05 07:22 AM
4Crawler Offline
4LO will make a difference, a BIG difference, in fact a 2.28 times difference, 1st gear will be over twice as low and 2nd gear will even be a bit lower than 1st gear is in high range.
Re: Heavy Duty Clutch??? [Re: 4Crawler] #675910 12/11/05 05:09 PM
yea i have to agree centerforce is the way to go ,you have sevral options also ,but the lowest option for em is about 30% better than stock so just get hte replacement version and your good to go.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6082 MB (Peak: 0.6776 MB) Data Comp: Off Server Time: 2026-06-10 07:02:41 UTC
