22RE headgasket - sealer or no?
#676593
12/13/05 03:33 AM
Re: 22RE headgasket - sealer or no?
#676594
12/13/05 06:30 AM
you mean permatex as well as a head gasket? id say hell no. just use a quality gasket....not felpro!!
87 4runner 33" bfg mt's no lift. dubbed the marine by my frinds. dead as of august 14 2005. 84 ex cab p/u 33"a/t, 3" suspension+3"bodylift, thorley header and 2.25xhaust, downey midrange cam+rocker set, very milled head! NO RUST!
[Re: lookmomnobrains]
#676595
12/13/05 07:10 AM
yes definitely use a toyota gasket... some people use thinner head gaskets to get a bit more compression but i never have and why mess with reliability for 1-3 HP? <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
if you have a haynes manual i believe there are a few spots it reccomends to have silicone on. i believe these are the water passages. i cant remember where or how much though.
otherwise no slicone on the headgasket.
#676596
12/13/05 10:33 AM
No sealer. You do apply a SMALL dab to each of the front corners of the block, but that is all. The valve cover half moons which go on the head after it's installed take a thin layer of sealant before being set in place, more so to hold them there when you put the valve cover back on. Cover gasket; no sealant. Make sure all your mating surfaces are CLEAN.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5972 MB (Peak: 0.6547 MB) Data Comp: Off Server Time: 2026-06-17 02:56:58 UTCValid HTML 5 and Valid CSS
