Window Cable Broke!!! #676925 12/14/05 04:23 PM
bumpcity76 Offline OP
I was rolling down the driver's side window yesterday (2001 2wd 2dr convt) when the window just dropped into the door! I got home and took the door panel off and saw that the cable was broken. Now what? There's not exactly a lot of room to work inside the door. Can the cable be repaired, or do I have to replace more? How do I work on this?
Thanks much,
Kris
Re: Window Cable Broke!!! [Re: bumpcity76] #676926 12/14/05 08:08 PM
Nukeiridium Offline
You have to take the window and motor out and replace the whole window motor assembly. If you have a manual it's not hard, just follow the instructions. The motor assembly is about $100 USD from the dealer here. I had to replace mine a while ago.
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: Window Cable Broke!!! [Re: Nukeiridium] #676927 12/14/05 10:35 PM
Cool, so the cable is part of the motor assembly and not the regulator aseembly? I just want to make sure I'm clear on that. I don't have manual, yet. Anyone suggest a good one?
Thanks,
Kris
Re: Window Cable Broke!!! [Re: bumpcity76] #676928 12/14/05 11:08 PM
MorganEstill Offline
The Kia one. It's the ONLY one. <img src="/forums/images/graemlins/drunk.gif" alt="" /> Too bad there's not a Chilton's...
'97 Sportage, 4" Lift 1" BL, 31" BAJA CLAWS, Rallye 4000s, Line-Xed Hood, Grille, K&N, 2.25" Exhaust, RS9000s, GPS...
"What is IFS and where can I get some??" (outerlimits4x4.com)
Re: Window Cable Broke!!! [Re: Nukeiridium] #676929 12/28/05 06:39 AM
The cable is broken, do I need a new motor or window regulator? Hopefully, not both. Also, does anyone have detailed procedures for this fix?
Thanks much,
Kris
Re: Window Cable Broke!!! [Re: bumpcity76] #676930 12/29/05 12:54 PM
Axe Man Offline
Kia Moderator Emeritus
Thanks much,
Kris
Go here: http://www.kiausaparts.com
That will tell you what parts you'll need to repair it.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: Window Cable Broke!!! [Re: Axe Man] #676931 12/29/05 05:03 PM
Thanks. Now, if I can get them to give it to me around the MSRP price and figure out how to change it out.
Thanks,
Kris
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6155 MB (Peak: 0.6894 MB) Data Comp: Off Server Time: 2026-06-07 03:10:19 UTC
