air pressure and mpg
#677198
12/15/05 08:36 AM
I went a little long on my last tire rotation and noticed that the middle of my front tires were almost bald while the edges were not as worn. The rears looked fine. When I rotated them, I lowered the fronts to 28 pounds hoping to even out the wear while keeping the rears at 35. I noticed tonight that my mpg dropped from the 14s to the 12s. Could the drastic drop be soley to the air pressure drop in the front tires or might there be something else going on? Thanks, Taro
Re: air pressure and mpg
[Re: taro]
#677199
12/15/05 01:25 PM
Yep, it sure could.
Wearing in the middle indicates you have way too much air pressure in the tires. Relieving some of that air pressure to put more contact patch on the ground, increases rolling resistance which will reduce fuel mileage.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake 1989 Trooper 2.6 auto 1989 I-Mark RS DOHC 1.6 1991 Stylus XS DOHC 1.8
[Re: litnin]
#677200
12/16/05 05:53 AM
Thanks for the reply. Gas is starting to go up again. I've been riding my motorcycle most days. If I go ahead and get some heated gloves, I think I'll be alright even down into the 20s provided there's no precipitation.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5921 MB (Peak: 0.6452 MB) Data Comp: Off Server Time: 2026-07-13 03:41:36 UTCValid HTML 5 and Valid CSS
