Convert to manual clutch? #677450 12/15/05 11:58 PM
DanWheeler Offline OP
anyone thought about converting to a manual clutch? I've about had it up to here with soft clutch pedals because of bubbles, or messed up pistons, master cylinder, slave cylinders etc... seems like once a year I have to bleed my system or replace one of the 4 major parts of the hydraulic clutch system.
any ideas?
1986 Montero 2.6l
31X10.5 BFG MT - Weber carb with custom intake
Rear LSD - RCI seats - Oil cooler - Manual hubs
Custom bumpers front and rear + rock sliders
Re: Convert to manual clutch? [Re: DanWheeler] #677451 12/16/05 08:39 AM
powerRam50 Offline
the trucks have a cable clutch you might be able to switch but you would need a truck transmission.also i replace my cable every 6 months becouse it always snapps on me.
Re: Convert to manual clutch? [Re: DanWheeler] #677452 12/18/05 04:07 AM
TobyB Offline
change your fluid more often.
Brake fluid is good for about a year, then it's absorbed a bunch of moisture- especially here in the dank Pac NW (well, except for this week)
Then everything rusts from the inside out.
fwiw,
t
'89 V6 4dr- '4- Doris'
Re: Convert to manual clutch? [Re: TobyB] #677453 12/19/05 10:34 PM
My B-I-L swears by silicone brake fluid. He says he has cars that have had it in for many, many years. None of them he says have ever needed caliper work. This sticking point is that the stuff is expensive and you need to fully bleed with it to accomplish the end goal.
Re: Convert to manual clutch? [Re: DanWheeler] #677454 12/19/05 11:14 PM
i guess part of my thinking was that converting to a manual clutch would be more reliable off road. if something ever happened to your master or slave cylinder off road you're pretty much screwed. At least with a manual clutch your just dealing with metal, hinges and springs for the most part. Much easier to MacGuyver something to get you back on the road if necessary.
<img src="/forums/images/graemlins/confused.gif" alt="" />
I wonder what cars out there would have something that might fit?
1986 Montero 2.6l
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6095 MB (Peak: 0.6741 MB) Data Comp: Off Server Time: 2026-11-17 11:21:47 UTC
