new one on me #677605 12/16/05 05:35 AM
johnu Offline OP
went to start my 98 trooper today. When it started I herd an unusual noise coming from the engine. I turned off the ignition and the starter motor was still turnning over the engine. I quickley popped the hood and pulled the negative off the battery. so the the starter is somehow stuck in its starting mode. what could be stuck to allow the starter to still run even if the ignition key is in the off position? you would think that if you turned off the ignition that would cut power to the starter. would the problem be in the key switch? any ideas would be welcome
Re: new one on me [Re: johnu] #677606 12/16/05 02:02 PM
Richard Saylor Offline
Could be that the solenoid is stuck to where it is always activated, thus causing it to continue running with or without the key in the ignition.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: new one on me [Re: johnu] #677607 12/16/05 06:36 PM
BigSwede Offline
I suspect the starter relay. Your key switch activates the relay, which activates the starter...so I'm thinking relay. That is the only way the starter could continue to get juice even with the key off.
Serenity now!
Re: new one on me [Re: BigSwede] #677608 12/17/05 05:37 AM
Cat_Fuzz Offline
It's doubtful that its the keyswitch or you wouldn't have been able to shut off the engine at all. Its probably the solonoid inside the starter is stuck. I could be the relay, I guess. A simple test would be to pull the relay and then reconnect the battery but then again, the starter solonoid may have unstuck but if it does crank with the relay removed, then its the starter solonoid.
Re: new one on me [Re: Cat_Fuzz] #677609 12/17/05 08:04 PM
onebadtrooper Offline
If you can get to the starter try tapping on the solonoid, It might free it long enough to get a new starter.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6046 MB (Peak: 0.6694 MB) Data Comp: Off Server Time: 2026-11-03 13:34:41 UTC
