Sigh...just had clutch replaced...now...synchronizors in Transmission suck #677791 12/17/05 02:38 AM
K9Troopin Offline OP
Help.
I had my clutch done early in '05...Just today I had it done again!
My current mechanic (old family friend that I trust implicitly) said he found the "synchronizors" or "synchronizing gears" were worn due to (possibly) the flywheel not being turned last time the clutch was worked on!
The previous shop that did the clutch work...are they at fault? If I can find the work order and they didn't turn it, do they pay for THIS last work? What are my chances of coming out on top?
Sigh. Little help here?
TIA
Dana
ps, email me privately if you would Tule_hound@webtv.net <img src="/forums/images/graemlins/patriot.gif" alt="" />
'91 LS Trooper~ 1.5" Susp. & 3" Body Lift, 33"BFG M/Ts, custom double sliders, Indy4x bumper,Herc'd lower body panels, Hella 550 lights, custom rear shelf and speaker box, customized console, blue grill strobe lights and wig-wag headlights
Re: Sigh...just had clutch replaced...now...synchronizors in Transmission suck [Re: K9Troopin] #677792 12/17/05 04:13 AM
JohninLV Offline
Try bleeding your clutch slave and master cylinder before you call your synchroes gone. Also might try dumping in a quart of Penzoil Synchromesh.
Just a thought
John in LV
3 90 Trooper V-6's, 5 speed, 4.3L TBI, 31" BFG AT's, Fender Flairs, Bored intake, 1.6 roller rockers, MSD Coil, Jacobs Omni ignition. Heavy duty torsion bars, Rancho 9000 Shocks CAN'T SPELL, TO OLD TO LEARN, GOD BLESS YOU IF YOU CAN.
Re: Sigh...just had clutch replaced...now...synchronizors in Transmission suck [Re: JohninLV] #677793 12/17/05 05:26 AM
Cat_Fuzz Offline
I don't understand how not having the flywheel turned can mess up synchros. Even so, theres no way you can pin this on the previous mechanic. You probably have something else wrong in the hydraulics.
Re: Sigh...just had clutch replaced...now...synchronizors in Transmission suck [Re: K9Troopin] #677794 12/17/05 05:48 AM
mlclark Offline
Isuzu Moderator
You are driving a 14 year old vehicle. Syncros are wear items. After 14 years, they will be worn.
I really do not think the flywheel had anything to do with it. Actually, I don't see how it could ever come close to causing the problem.
I agree with the above. Right now, bleed/replace the hydraulics and change the fluid in the transmission. At the best, it will make it driveable. At the worst, it is time for a new/used tranny or a rebuild.
Good Luck,
Michael
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6032 MB (Peak: 0.6591 MB) Data Comp: Off Server Time: 2026-10-24 13:09:52 UTC
