Heater Issues #677970 12/17/05 10:01 PM
W
Wildcat_4R Offline OP
My heater stopped working yesterday. More specifically, the blower is not getting power. The motor itself is working and I found that the resistor pack is good as well. When I turn the dash switch to the on position, I can hear the relay click behind the dashboard giving me reason to believe it is working as well. Am I overlooking anything in between the relay and the resistor pack (fuse, another relay) or do you think I just have a short in the power wires to the blower. Just wanted to ask before I started ripping into the wiring.
1987 4-Runner with a "slightly modified" 22RE
Re: Heater Issues [Re: Wildcat_4R] #677971 12/17/05 11:27 PM
willzrunna96 Offline
if i remember correct there is another tiny fuse block with 2 fuses in it. i know one is for a/c but not sure about the other. Its right by the door flap. otherwise id say check your grounds
Re: Heater Issues [Re: Wildcat_4R] #677972 12/17/05 11:53 PM
4WD22R Offline
behind the glove box and to the left is the fuse box that willz is talking about, and yes, one is for the heater and the other is for the a/c, give it a look, I believe that they are 20's and 30's.
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Heater Issues [Re: 4WD22R] #677973 12/18/05 02:50 AM
SHAD Offline
Well something is causing it to short it maybe the motor going bad.
Have you tryed to spin it by hand with it on low?
How did you test the motor?
Also what did you do to test the blower resistor?
You sure one of those aren't bad?
86 Toyota 4 runner
35x12.5 BFG MT's, 4.56's XRC8 winch
My cardomain page
Re: Heater Issues [Re: SHAD] #677974 12/18/05 07:11 AM
W
It was the heater fuse in the little tiny fuse block. Doh! Didn't know that little bugger was there. Took a look and sure enough, the 20amp heater fuse was blown. Everything else checked out fine. Heater works now. Thank you all for your help and pardon my blindness.
Re: Heater Issues [Re: Wildcat_4R] #677975 12/18/05 08:56 AM
4WD22R Offline
yup that one's hidden pretty good! found that puppy when I was throwin a new heater core in....
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
--George W. Bush
Re: Heater Issues [Re: Wildcat_4R] #677976 12/18/05 02:40 PM
Keep an eye on it and if it blows again you got a problem.....but I spose you already knew that <img src="/forums/images/graemlins/shiner.gif" alt="" />
Fuses will sometimes get tired and go....even though nothing is wrong.
Re: Heater Issues #677977 12/18/05 05:59 PM
4Crawler Offline
I describe that fuse on my blower repair page:
- http://www.4crawler.com/4x4/CheapTricks/Blower.shtml#BlowerResistor
If you find the fuse blowing again, you might have a look at the brushes inside the blower motor. When they start to wear out, they can cause excessive current flow in the motor. When mine went, I never blew that fuse, but I did have trouble with the blower motor overheating and shutting down periodically:
- http://www.4crawler.com/4x4/CheapTricks/Blower.shtml#MotorRepair
Re: Heater Issues [Re: 4Crawler] #677978 12/19/05 12:43 AM
I
irsean Offline
My blower control only works on MAX. Is there an easy fix or am I replacing the switch?
1993 4Runner SR-5 4WD V-6 Auto Trans
1990 Pick-up (Hilux) 2WD SR-5 V-6 Auto Trans
Re: Heater Issues [Re: irsean] #677979 12/19/05 12:46 AM
4Crawler Offline
Read the page I posted a link to above:
First line of text there is:
"My blower only works on high speed..."
The rest of the page has the fix.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6383 MB (Peak: 0.7620 MB) Data Comp: Off Server Time: 2026-06-07 02:29:54 UTC
