Heater Issues
#677970
12/17/05 10:01 PM
My heater stopped working yesterday. More specifically, the blower is not getting power. The motor itself is working and I found that the resistor pack is good as well. When I turn the dash switch to the on position, I can hear the relay click behind the dashboard giving me reason to believe it is working as well. Am I overlooking anything in between the relay and the resistor pack (fuse, another relay) or do you think I just have a short in the power wires to the blower. Just wanted to ask before I started ripping into the wiring.
1987 4-Runner with a "slightly modified" 22RE
Re: Heater Issues
[Re: Wildcat_4R]
#677971
12/17/05 11:27 PM
if i remember correct there is another tiny fuse block with 2 fuses in it. i know one is for a/c but not sure about the other. Its right by the door flap. otherwise id say check your grounds
91 pickup 5.29's US GEAR.35x 12.50 trxus m/t.5 speed swap- SOLD! 96 4Runna limited-toytec/OME lift,diff drop Nitto 285/75/16 Elocked=butter 07 FJ cruiser 3" DR coilovers 285/75/16 nitto TG. allpro sliders
Re: Heater Issues
[Re: Wildcat_4R]
#677972
12/17/05 11:53 PM
behind the glove box and to the left is the fuse box that willz is talking about, and yes, one is for the heater and the other is for the a/c, give it a look, I believe that they are 20's and 30's.
-1986 TOYOTA 22R ZUK coil rear Torqued T-Bars Marlin HD clutch
AZTTORA #492 TLCA member
"I hear there's rumors on the Internets that we're going to have a draft." --George W. Bush
Re: Heater Issues
[Re: 4WD22R]
#677973
12/18/05 02:50 AM
Well something is causing it to short it maybe the motor going bad. Have you tryed to spin it by hand with it on low? How did you test the motor? Also what did you do to test the blower resistor? You sure one of those aren't bad?
Re: Heater Issues
[Re: SHAD]
#677974
12/18/05 07:11 AM
It was the heater fuse in the little tiny fuse block. Doh! Didn't know that little bugger was there. Took a look and sure enough, the 20amp heater fuse was blown. Everything else checked out fine. Heater works now. Thank you all for your help and pardon my blindness.
Re: Heater Issues
[Re: Wildcat_4R]
#677975
12/18/05 08:56 AM
yup that one's hidden pretty good! found that puppy when I was throwin a new heater core in....
Re: Heater Issues
[Re: Wildcat_4R]
#677976
12/18/05 02:40 PM
Keep an eye on it and if it blows again you got a problem.....but I spose you already knew that <img src="/forums/images/graemlins/shiner.gif" alt="" />
Fuses will sometimes get tired and go....even though nothing is wrong.
Re: Heater Issues
[Re: 4Crawler]
#677978
12/19/05 12:43 AM
My blower control only works on MAX. Is there an easy fix or am I replacing the switch?
1993 4Runner SR-5 4WD V-6 Auto Trans 1990 Pick-up (Hilux) 2WD SR-5 V-6 Auto Trans
