Page 1 of 5 1 2 3 4 5
Weber conversion on the fly, need help please. #678194 12/18/05 08:55 PM
juggernaut Offline OP
HELP! My carb body has cracked so I am trying to swap for a Weber 38dgas I have. Ant body got diagrams or instructions what to do with all these vacuums and such?
http://catocom.com/forum/showthread.php?t=1558
2001 Jeep Wrangler Sahara/4" Rough Country Lift/BFG 32x11.5x15
I caught this "JEEP thing" of your and now it hurts when I pee.
Re: Weber conversion on the fly, need help please. [Re: juggernaut] #678195 12/19/05 08:22 AM
LRJ4x4 Offline
Did your mikuni crack or your old weber?
Re: Weber conversion on the fly, need help please. [Re: juggernaut] #678196 12/19/05 09:04 PM
DanWheeler Offline
plug em all up. there's only one vacuum line you need with the Weber - the vacuum advance.
the rest of them are useless without the mikuni. just make sure you dont have any vacuum ports unplugged on the intake manifold and you should be good.
1986 Montero 2.6l
31X10.5 BFG MT - Weber carb with custom intake
Rear LSD - RCI seats - Oil cooler - Manual hubs
Custom bumpers front and rear + rock sliders
Re: Weber conversion on the fly, need help please. [Re: DanWheeler] #678197 12/19/05 10:03 PM
Yeah, the mikuni cracked and left me stranded so I am trying to swap in the weber. I got it bolted on and the linkage in place but not sure which vacuum to connect and how to route the fuel into it. I am trying to match the pix from the donor but not detailed enough.
Re: Weber conversion on the fly, need help please. [Re: juggernaut] #678198 12/19/05 10:06 PM
Also where do I hook power from.
Re: Weber conversion on the fly, need help please. [Re: juggernaut] #678199 12/19/05 11:10 PM
DanWheeler Offline
assuming by electrical you mean the electric choke? i think you can take a +12v lead off the coil that is only on when the ignition is on. Make sure you check the voltage and get the right one. the only other vacuum line goes from the carb to the vacuum advance on top of the distributor.
fuel should be pretty easy. Unless you took the fuel pump off, just connect the line you have hanging to the Weber.
1986 Montero 2.6l
Re: Weber conversion on the fly, need help please. [Re: DanWheeler] #678200 12/19/05 11:32 PM
Didnt switch out fuel pump. Isnt there two lines that come out of it. Need to go look at the manual that my Dad has. Wish I was home, mine are better.
Let me check the voltage and get it hooked up.
Also curious to see your intake setup, gonna need to get (make) something better.
I appreciate the help. I gotta get home by Wednesday, start new job.
Re: Weber conversion on the fly, need help please. [Re: juggernaut] #678201 12/20/05 01:28 AM
DanWheeler Offline
you're kind of on your own for an air cleaner setup. you can use the air filter that comes with the 38 or you can make something from junk yard parts. Take a look at these plenums:
Weber plenums from carbs.net
1986 Montero 2.6l
Re: Weber conversion on the fly, need help please. [Re: juggernaut] #678202 12/20/05 02:54 PM
NathanC Offline
I'd recommend swapping the electric choke for a manual one. You can modify a manual choke kit from any parts store to work.
You will only need to hook up the supply line to the carb. I would also recommend removing the old mechanical and blocking off the hole. Replace it with an electric pump, you'll be much happier. Trust me <img src="/forums/images/graemlins/notooth.gif" alt="" />.
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: Weber conversion on the fly, need help please. [Re: NathanC] #678203 12/20/05 07:15 PM
DanWheeler Offline
I'll second the recommendation on the manual choke and the electric fuel pump. <img src="/forums/images/graemlins/kewl.gif" alt="" />
1986 Montero 2.6l
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6434 MB (Peak: 0.7637 MB) Data Comp: Off Server Time: 2026-05-30 01:06:25 UTC
