hub question 89 truck #678353 12/19/05 03:17 PM
trythis Offline OP
I just got my truck and I have a question about the hubs.
One of them is very easy to turn, it just snaps in and out of place. The other take a grunt or two to turn it.
Is this normal or is there a problem? I don't mind tearing them open and I should probably repack teh wheel bearings since I have no idea about mainetance the history. (actually, I think it had no maintenance) It has 130,000 miles.
Re: hub question 89 truck [Re: trythis] #678354 12/19/05 06:19 PM
Seattlegti Offline
Probobly just needs to be repacked. How do the CV boots look?
Re: hub question 89 truck [Re: trythis] #678355 12/19/05 08:00 PM
OOP'S Offline
At the top of this page there it a FSM for a 93. All the info you need for cleaning and the procedure for inspecting and the proper way they go to together is there. Use a liberal amount of grease on the hubs otherwise they will not work properly. I use a white lithimun based grease on the hubs. The procedure for packing the wheel bearings is also there.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: hub question 89 truck [Re: Seattlegti] #678356 12/20/05 12:35 AM
trythis Offline OP
cv boots look fine, I don't think this truck saw anything worse that a nasty farm road or two, the bottom is clean and scratchless.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6009 MB (Peak: 0.6563 MB) Data Comp: Off Server Time: 2026-06-10 06:31:22 UTC
