Rust on a spindle #678418 12/19/05 07:49 PM
JWHnAtl Offline OP
Is rust on a spindle (sat out for a while) that bad? Should the rust be cleaned off before using the spindle? If so, what would be the best method?
Thanks in advance!
'89 3.0 4Rnr: Jacob's Electronics, K&N, CF Dual Frict, 4:56 w/ Truetracs, 33 BFG AT/KOs, Cascade Audio, Pro-Comp 4" susp & 2" body (previous owner)
I know, a lot of wasted time and money ... if I knew then what I know now....
Re: Rust on a spindle [Re: JWHnAtl] #678419 12/19/05 08:03 PM
OOP'S Offline
I use a wire wheel mounted on an electric motor for cleaning up rusted stuff. Or enery cloth and elbow grease!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Rust on a spindle [Re: OOP'S] #678420 12/19/05 08:16 PM
JWHnAtl Offline OP
Thanks! I've got a dremel-like tool with wire wheels, but I was afraid of putting too many scratches on the spindle. I also have some polishing wheels that I was thinking of trying. I just didn't know whether the rust was a big deal or not. It's more like rust spots.
Re: Rust on a spindle [Re: JWHnAtl] #678421 12/19/05 09:25 PM
Red_Chili Offline
Toyota Section Staffer
Naval jelly. Use gloves though!! <img src="/forums/images/graemlins/scared.gif" alt="" />
-Bill
Re: Rust on a spindle [Re: Red_Chili] #678422 12/19/05 09:35 PM
TexJeff87 Offline
Naval jelly. <img src="/forums/images/graemlins/scared.gif" alt="" />
Is that a variation of toe jam? Takes a while to save up a usable ammount, I bet.... <img src="/forums/images/graemlins/barf.gif" alt="" />
If Mad Max had a 4runner...
Re: Rust on a spindle [Re: TexJeff87] #678423 12/19/05 10:12 PM
4Crawler Offline
A wire wheel won't scratch the spindle. You can also try steel wool or one of the synthetic abrasive pads. The other thing that works well is the CLR or LimeAway bathroom cleaner. Both are phosphoric acid-based, just like Naval Jelly and do the same thing.
Re: Rust on a spindle [Re: 4Crawler] #678424 12/20/05 12:38 AM
JWHnAtl Offline OP
Thanks to everyone for the responses. I know about CLR and should have thought about that. I have no idea where to get naval jelly so I think I'll try the CLR.
Thanks again! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Rust on a spindle [Re: TexJeff87] #678425 12/20/05 12:40 AM
JWHnAtl Offline OP
<img src="/forums/images/graemlins/lol.gif" alt="" />
I know about naval lint, but not naval jelly! <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: Rust on a spindle [Re: JWHnAtl] #678426 12/20/05 01:27 AM
4Crawler Offline
Any decent hardware store will have it, a pink gel in a small bottle.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6323 MB (Peak: 0.7347 MB) Data Comp: Off Server Time: 2026-05-29 19:50:53 UTC
