lost my brakes! #678506 12/20/05 02:27 AM
1
1986xtracab Offline OP
So as I was on my lunch brake today i was driving and came to a stop behind some car. As they moved forward a bit I did the same but as I went to hit my brakes it felt like they were working and then went to the floor. I still had some brake power (very little) and luckly I was close to work, so I drove it back and parked it. I popped the hood and the master cylinder was still full of brake fluid. I had a friend come out and push the pedal while I listened for leaks, I checked all 4 wheels and there was nothing. It sounds like theres a leak coming from the master cylinder. like air blowing by. I am I right thinkg it's dead? if so any brand I should look to replace it with? Or A upgraded one from a V6 or something?
Re: lost my brakes! [Re: 1986xtracab] #678507 12/20/05 07:21 AM
4WD22R Offline
Maybe a bubble in the system? It can sometimes happen randomly. Had a '94 $hit-10(S-10 that is) where this just randomly happened, bleeding the brakes fixed the problem. My understanding is that when the MC goes bad, it leaks all over the truck(thats what my buddy's '84 did), and takes any paint that it touches with it. If you do replace it, don't use ANYTHING but OEM parts!!! It may sound stupid but trust me, from personal experiance, and the experence of many others here, nothing else seems to come even close to OEM quality. Using anything else just sets yourself up to fix it again.....I learned this after getting 5 'lifetime warranty' water pumps replaced...I guess NAPA water pumps lifetime is about 5K miles....<img src="/forums/images/graemlins/rolleyes.gif" alt="" /> BTW, I'm REALLY good at changing those things now <img src="/forums/images/graemlins/smile.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: lost my brakes! [Re: 4WD22R] #678508 12/20/05 01:07 PM
hdrisc Offline
Bad vacuum booster perhaps?
Re: lost my brakes! [Re: 1986xtracab] #678509 12/20/05 01:17 PM
CraShYota Offline
I would say your brake booster has gone. Brake booster is the thing that sits behind the mastercyl.
Welding and Fabrication Engineer
2003 taco V6 ext cab sr5
1988 Toyota Pickup V6(totaled)
Re: lost my brakes! [Re: CraShYota] #678510 12/20/05 10:08 PM
1
It was the master cylinder and now it's all good!
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6081 MB (Peak: 0.6732 MB) Data Comp: Off Server Time: 2026-11-19 23:56:19 UTC
