Frame Interchange between 88 and 89 toyota truck? #678549 12/20/05 03:59 AM
W
wildyota Offline OP
Hi, Long time reader, first post... Anyway I have an 89 standard cab 4x4 truck with a bad frame, bad engine great body. I have an opportunity to purchase an 88 standard cab 4x4 truck with good frame, good engine but bad body. My question is are the cab and doghouse mounting locations on the frame the same between the body style change? I have placed a 91 bed on an 86 truck without any problems and am wondering if I can swap an entire frame between the different generation trucks without too many headaches. My plan is to place the 89 body on the good 88 frame. The reason I think this can be done is that the 89 4runners retained the old body while the p/u's went to the newer body and I'm not sure if yota used different frames. Let me know your thoughts. I tried to do a search but didn't come up with much.
88 4x4 Toyota - Stock -
Re: Frame Interchange between 88 and 89 toyota truck? [Re: wildyota] #678550 12/20/05 08:06 AM
4WD22R Offline
AFAIK you're right on, swap away and feel happy!
BTW how did the '91 bed look on the '86? any pics?
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Frame Interchange between 88 and 89 toyota truck? [Re: 4WD22R] #678551 12/20/05 04:11 PM
W
wildyota Offline OP
Thanks for the response! I'll let you know how things go. I need to do some more checking and measuring before I take the plunge.
I don't have any pics of the bed. I don't have a digital camera yet... The truck it's on is just a work beater. The bed is black and the cab is blue so it looks odd but the body lines align up pretty decent. If it was painted the same color I don't think anyone would notice unless they really knew yotas.
Re: Frame Interchange between 88 and 89 toyota truck? [Re: wildyota] #678552 12/21/05 03:44 PM
fourwd1 Offline
I put a 2nd gen 2WD body on my 1st gen 4WD frame with only some minor work, so I'd think what you want to do is very possible, maybe even easier. Beds seem to be totally interchangeable.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6028 MB (Peak: 0.6586 MB) Data Comp: Off Server Time: 2026-06-09 23:39:06 UTC
