power steering pumps #678853 12/21/05 05:02 AM
Thanks for hosting a great site from a first time poster child. I was wandering about the quality of the Maval power steering pumps sole by Drivewire. Specifically the one for the '95 4runner dw138550102 or dw427201102m. If the "mechanic" says the pump leaks, is the thing roached. Is there such a thing as bench testing the pump? Are there seals that can be replaced in order to save me the 579.00 shekels the guy quoted me? thanks in advance
Re: power steering pumps #678854 12/21/05 05:31 AM
kewlynx Offline
You can get them out of a junkyard; www.car-part.com
OR rebuild http://personal.utulsa.edu/~nathan-buchanan/93fsm/steering/11powerste.pdf
IIRC, there's a writeup on Yotatech also.
If you were using cheapazz power steering fluid instead of Dextron II or III, that would cause your seals to leak. You 'might' get lucky to flush the fluid you have in there and replace it with the recommended stuff.
**ubi apis- ibi salus**
Re: power steering pumps [Re: kewlynx] #678855 12/21/05 08:17 AM
themainjam Offline
lol thats funny considering my power steering reservoir says to use ATF. lmao. (99 4runner)
but yeah save yourself some money and get what he said.
EDIT: sorry misread sounded like your were a cheap ass if you used ATF lol.
Re: power steering pumps [Re: themainjam] #678856 12/22/05 05:11 AM
themainjam, ATF will go fine but we don't use ATF on our power steering we use motor oil and a friend of mine use motor oil on his manuel transmission he said it work the same but he told me do not use it on automatic transmission... <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: power steering pumps #678857 12/22/05 07:04 AM
Coyotekid Offline
ATF will go fine, people I know even use motor oil and even use motor oil to go in there transmission but only for manuel transmission, do not use it on automatic transmission... <img src="/forums/images/graemlins/smile.gif" alt="" />
...what?
~~~The more People I meet, the more I like My Dog..~~~
-96' Tacoma 3.4 4x4 5 Speed, Trueflow intake+Deckplate, 2.5 inch Magnaflow Cat-back,OME 881's, and some extra-leaves in the rear..
-68' Chevelle Malibu..Stage one of Restoration: *Collecting funds* <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: power steering pumps [Re: themainjam] #678858 12/22/05 07:21 AM
kewlynx Offline
Emmmmm....
Dextron II or III *is* ATF....
The cheap stuff is not.....
AND do not mix with Type F; it's not recommended (by Mobil at least)
Toyrunner.......????????? >coff<
Re: power steering pumps [Re: Coyotekid] #678859 12/22/05 07:30 AM
4WD22R Offline
...what?
He's baaaack....... <img src="/forums/images/graemlins/scared.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6136 MB (Peak: 0.7073 MB) Data Comp: Off Server Time: 2026-06-20 19:16:55 UTC
