loud valve tick noise when under load, what is this? #679612 12/24/05 01:18 AM
It is when under load, I notice it a low rpm's like 1800'ish. It is quite loud, but I have no other signs of anything going bad. I have 70K now, oil stays clean and full. No smoke. What is going on?
Re: loud valve tick noise when under load, what is this? #679613 12/24/05 09:43 AM
regularman Offline
Are you sure its not an exhaust manifold leak? It will sound similar but will leak out more in a hard pull. If it is leaking you might have a converter stopping up.
Re: loud valve tick noise when under load, what is this? [Re: regularman] #679614 12/25/05 07:43 AM
No I am not sure, How would I rule out or confirm an exhaust leak? Thank you for the reply.
Re: loud valve tick noise when under load, what is this? #679615 12/26/05 01:59 AM
regularman Offline
You might try getting on a real steep hill and raise the hood and have someone drive it in 4wd low in 1st gear and see if yu can hear it. You should be able to hear it at an dile though just not very loud. Mine started to leak between the exahust manifold and the exhaust pipe going out at the flange when the catylic converter started stopping up. I would just raise the hood and start it up and reve the motor by pulling the gas cabel from under the hood and see if you can hear it.
Re: loud valve tick noise when under load, what is this? [Re: regularman] #679616 12/26/05 02:06 AM
Regularman, Thanks for your time, I will try that. If it were some part of my engine, wouldn't I notice a power decrease or some other sign?
Re: loud valve tick noise when under load, what is this? #679617 12/26/05 02:10 AM
Regularman, Happy Birthday, you've been a member for one year today.
Re: loud valve tick noise when under load, what is this? #679618 12/27/05 08:15 AM
regularman Offline
I had not even noticed that. good luck finding the noise
Re: loud valve tick noise when under load, what is this? [Re: regularman] #679619 12/29/05 12:46 PM
Axe Man Offline
Kia Moderator Emeritus
Are you sure this is a "tick" and not a "knock"? The DOHC engine likes to piston slap. It's normal for this engine. It is MUCH louder when the engine is cold and under load. As the engine warms the noise decreases but never goes away completely.
To answer your e-mail. I don't think a compression test will tell you much unless the noise suddenly came about and wasn't doing it before.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: loud valve tick noise when under load, what is this? [Re: Axe Man] #679620 12/30/05 07:41 AM
Axe, It is a little deeper sounding than a tick, I think this might be it. If it is, then I am feeling lots better.
Thanks a lot. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6194 MB (Peak: 0.7042 MB) Data Comp: Off Server Time: 2026-05-29 16:12:01 UTC
