how do i kill the fuel pump power #679631 12/24/05 02:56 AM
I need to kill the power to the fuel pump so I can change my fuel filter but I don't see a fuel pump fuse. Is it on the one that says EFI ? If not how do I do it?
Re: how do i kill the fuel pump power #679632 12/24/05 03:11 AM
Adam F Offline
I don't think there is a fuel pump fuse. But from what I can remember, it is tied into the EFI fuse.
Why not just disconnect the battery?
Oh...and here's a link that might help with the job
http://www.4x4wire.com/toyota/maintenance/30_V6/fuel_filter/
If you have a body lift it will make it a lot easier.
97 4R, stock, daily driver
Re: how do i kill the fuel pump power [Re: Adam F] #679633 12/24/05 06:41 AM
I wanted to kill the pump with the motor running so i could empty the lines of fuel before I take them off. Thanks for the link but it really doesn't tell how to shut the fuel pump off with the motor running. best I can find is the Haynes manual says to unplug the pump power source at the pump.
Re: how do i kill the fuel pump power #679634 12/24/05 07:02 AM
kewlynx Offline
It's a safety issue.......... <img src="/forums/images/graemlins/shame.gif" alt="" />
**ubi apis- ibi salus**
Re: how do i kill the fuel pump power #679635 12/24/05 07:13 AM
Adam F Offline
When I did mine I just slowly loosened the line and let the fuel come out. It diddnt shoot out or anything, just a little flowed out. Nothing to worry aout.
Re: how do i kill the fuel pump power [Re: Adam F] #679636 12/24/05 08:48 PM
I guess that's what i'll do too. I just hate to have all that gas in a drain pan. Sometimes I have enough static electricity in me to light a 60 watt bulb, talk about a safety issue....
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
MERRY CHRISTMAS ALL !
Re: how do i kill the fuel pump power #679637 12/24/05 11:05 PM
Adam F Offline
Go to RadioShack and get yourself an anti-static ground strap that goes on your wrist. Hook it to the frame and your good to go!
http://www.radioshack.com/product/i...p;amp;kw=strap&parentPage=search
Re: how do i kill the fuel pump power #679638 01/05/06 04:55 PM
mt_goat Offline
It helps if you take off that polyester sweater <img src="/forums/images/graemlins/notooth.gif" alt="" />
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: how do i kill the fuel pump power #679639 01/05/06 10:39 PM
fourwd1 Offline
There is a bleed off fitting at the end of the fuel rail, just drain the gas into a small container.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: how do i kill the fuel pump power #679640 01/06/06 05:50 AM
ufjaz Offline
Under the backseat (driver side) is an access plate in the floor with three screws. Open it and you'll find a harness plug that runs into the gas tank access plate. Unplug it with the truck running and it will run the truck dry.
I just did it today. Easier than I thought it would be. (for once!)
1996, 2wd, auto trans, deck plate, Addco sway bars, 17 wheels, Borla Cat Back, TRD headers, TRD SC, Bilstein shocks, 4.10 regear, TRD LSD, L10 VB/TC/PTS mods, Hayden tranny cooler, FTC1, 305 cc FI, Supra MAF, Walbro fuel pump
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6289 MB (Peak: 0.7307 MB) Data Comp: Off Server Time: 2026-06-20 17:28:02 UTC
