Vacuum Hose Routing #680202 12/27/05 04:11 AM
I
isensee Offline OP
I just did a valve job and put headers on my '93 4runner with V6. I am not certain I got all the vacuum hoses on correctly. There is a good illustration in the factory repair manual for the vacuum hoses related to the EGR and PAIR valves so I think I have those right. But I can't find anything that clearly shows where to connect the vacuum hoses that go to the power steering and the two hoses that run to a valve mounted on the fender (not sure what this valve is).
I have posted a couple of pictures that show how I have connected the hoses at http://members.aol.com/isensee/4runner1.jpg and http://members.aol.com/isensee/4runner2.jpg. Does it look correct? If not, can anyone tell me what I need to change or point me to a picture that shows the correct hose connections?
Scott Isensee
Re: Vacuum Hose Routing [Re: isensee] #680203 12/27/05 04:20 AM
4Crawler Offline
P/s hoses hook to the idle-up valve and intake. No in or out on them, just hook one side to the intake vacuum and the other side to the idle up valve (should have an RPM adjustmnent knob on it). The fender hoses may be for ADD, if you have that type of front axle:
- http://www.off-road.com/toyota/tech/add/index.htm
Re: Vacuum Hose Routing [Re: isensee] #680204 12/27/05 06:20 PM
If someone could send me a picture of how the hoses attach to the intake manifold on another '93 V6 that would really help me out.
Re: Vacuum Hose Routing [Re: isensee] #680205 12/27/05 07:31 PM
Marc91runner Offline
'91 4Runner SR5 V6 4X4 Auto, A/C (self installed)
4.56, 31x10.5x15 Nokian Vatiiva's
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5977 MB (Peak: 0.6560 MB) Data Comp: Off Server Time: 2026-06-13 10:45:07 UTC
