Tie rods, Pitman arm, Idler arm....That's a Full Days Work!!!! #680520 12/28/05 08:12 AM
4WD22R Offline OP
So I'm replacing the entire front steering assembley, minus the relay rod cause she's still holdin in there....I was just wondering if anyone had any tips/tricks on working on this stuff to offer up so my job could go a bit smoother.
Also, I'll be rebuilding my power steering gear box here in a couple of weeks, because I'm too cheap to shell out the $200-$400 for a rebuilt one, much less the $2000 that the stealer told me that they wanted <img src="/forums/images/graemlins/zombie.gif" alt="" /> Plannin on takin lots of pictures, maybe write up a tech article for the new Archive secton......
Thanks in advance guys and gals!
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Tie rods, Pitman arm, Idler arm....That's a Full Days Work!!!! [Re: 4WD22R] #680521 12/28/05 09:02 AM
toy94x4 Offline
I've only changed my idler arm so far. It was pretty straight forward. Three bolts and with the aid of a pickle fork & a 3lb hammer, it came right off. And the castleated nut too. Took no more than a half hour. Good luck with it all.
1994 P'up, 22RE, K&N, LCE exhaust sys (header, cat, muffler, 2.25" pipe), 1" RB seat lift, 1" RB body lift, 1.5" rear lift via shackles, Rancho 5000's, 33" Pro Comp M/T's, 4.88's w/ Aussie lockers front & back
Re: Tie rods, Pitman arm, Idler arm....That's a Full Days Work!!!! [Re: 4WD22R] #680522 12/28/05 10:36 AM
ldivinag Offline
go to HARBOR FREIGHT and ppick up their $6 tie rod and pitman arm puller...
the tie rod one saves you from beating on the things...
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: Tie rods, Pitman arm, Idler arm....That's a Full Days Work!!!! [Re: 4WD22R] #680523 12/28/05 01:47 PM
ACES_HI Offline
The pitman arms gonna be a problem. Even with a puller they dont want to come off. You can try the puller keeping pressure on it and tapping with a bfh. I ended up cutting mine off with an angle grinder which is actually the easiest way to do it. Just dont cut into the splines. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
Re: Tie rods, Pitman arm, Idler arm....That's a Full Days Work!!!! [Re: ACES_HI] #680524 12/28/05 02:57 PM
TexJeff87 Offline
If you soak it good in penetrant for a few days in advance, then use a propane torch to heat the arm while the puller is putting pressure on it, it will come loose. The heat of the torch will expand the arm just enough to let it slide off. Be patient...
If Mad Max had a 4runner...
Re: Tie rods, Pitman arm, Idler arm....That's a Full Days Work!!!! [Re: ACES_HI] #680525 12/28/05 11:02 PM
I
irsean Offline
Thank GAWD for my pneumatic picklefork. Pulling the idler arm was easier than rebuilding it (I use the rebuild kit instead buying another one).
1993 4Runner SR-5 4WD V-6 Auto Trans
1990 Pick-up (Hilux) 2WD SR-5 V-6 Auto Trans
Re: Tie rods, Pitman arm, Idler arm....That's a Full Days Work!!!! [Re: TexJeff87] #680526 12/28/05 11:23 PM
W
wave Offline
Been there! I broke two of the harbor freight pullers on my ball joints. I rented one from Auto Zone for a $20 deposit and it worked great. For the pitman arm, I used the grider w/ a cutting disc. Two slices and it released the tension, the puller then took it off. I broke a pickle fork before I got the puller.
Good Luck!
Anthony
Re: Tie rods, Pitman arm, Idler arm....That's a Full Days Work!!!! [Re: wave] #680527 12/29/05 01:17 AM
4WD22R Offline OP
Hmmmm so it sounds like the pittman arm is gonna be the fun part. I got the entire idler arm assembley so no worries about pullin that thing, three bolts and disconnect it from the relay rod and I'm done <img src="/forums/images/graemlins/smile.gif" alt="" /> I am looking foreward to some steering that is actually tight though. It's pretty bad now, if you watch the pittman arm to relay rod connection while I wiggle the wheel it's got about 3 inches of play <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> can someone say "near failure"?
Thanks for the help guys!
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
--George W. Bush
Re: Tie rods, Pitman arm, Idler arm....That's a Full Days Work!!!! [Re: 4WD22R] #680528 12/29/05 06:40 AM
TexJeff87 Offline
Not to sound like a dub-a$$, but why do you need to pull the pitman arm at all? What is there to wear out?
Re: Tie rods, Pitman arm, Idler arm....That's a Full Days Work!!!! [Re: TexJeff87] #680529 12/29/05 07:01 AM
kyle-22r Offline
the pitman arms on IFS trucks have the rod end built into them, rather than having a taper for a tie rod end like the knuckles.
it's considered a wear item though i don't think they go out all that often -- i picked up a moog unit from carquest today for a little over $50.
'91 4x4 shortbed
22R-E, W56, the dd!
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6401 MB (Peak: 0.7639 MB) Data Comp: Off Server Time: 2026-05-29 14:46:06 UTC
