EGR Valve replaced and... #680642 12/28/05 09:35 PM
glock Offline OP
...a month later symptoms- rough idle and intermittant stalling when put into neutral- have returned and the "check engine" light is beckoning.
The symptoms were constant- as was the light- for 3 days. Today? No light and no symptoms.
A little help over here pleeease!??
TIA
2012 Jeep Liberty
2000 Trooper 3.5, LS/Burgandy & Grey(O.B.T.2)...<img src="/forums/images/graemlins/cheers.gif" alt="" />
I WAS down with O.B.T. '88 Trooper II
("Old Blue Trooper!" said my kids!...)
Re: EGR Valve replaced and... [Re: glock] #680643 12/29/05 03:17 AM
A
Amigo-2k Offline
sounds like a classic intake manifold gasket problem
It can come and go depending on the leak.
Re: EGR Valve replaced and... [Re: Amigo-2k] #680644 12/29/05 05:53 PM
glock Offline OP
Lovely...I had both replaced while under warranty a year and change ago.
When I had the check engine light and symptoms checked a couple of months back the EGR valve was replaced and all was well. Whats up with that?
<img src="/forums/images/graemlins/confused.gif" alt="" />
2012 Jeep Liberty
Re: EGR Valve replaced and... [Re: glock] #680645 12/29/05 11:18 PM
Bigpoppax2 Offline
Are you getting a bank one or two lean code?
If so then the lower intake manifolds are most likely the problem.
Joe
Re: EGR Valve replaced and... [Re: Bigpoppax2] #680646 12/30/05 05:23 PM
glock Offline OP
Joe
I dropped off @ my mechanics this morning. Not equipped to know what the codes were, but your money is on the blown gasket?
<img src="/forums/images/graemlins/frown.gif" alt="" />
2012 Jeep Liberty
Re: EGR Valve replaced and... [Re: glock] #680647 12/30/05 11:47 PM
glock Offline OP
Intake maifold gasket it is...
Thats twice in two years now. Anything I can do to head of these bi-annual occurences!?? <img src="/forums/images/graemlins/angry.gif" alt="" />
2012 Jeep Liberty
Re: EGR Valve replaced and... [Re: glock] #680648 01/02/06 11:14 PM
had the same problem here. replaced intake manifold, and then had that replaced a year later, just barely under warrantee from the first repair. then a couple of weeks later had vacuum leak repaired. that was last december a year ago.. been using sea foam in gasoline every couple thousand miles since, and havent had a problem. keeping my fingers crossed tho.
Re: EGR Valve replaced and... #680649 01/03/06 02:00 AM
Bigpoppax2 Offline
The new part number is a newer part number and is not prone to the cracking. I don't know when the new part number came out. But, if I'm not mistaken it's got a 538 in it.
Joe
Re: EGR Valve replaced and... [Re: Bigpoppax2] #680650 01/03/06 05:44 AM
JLEMOND Offline
HEY JOE THAT NEW PT NO IS 8972375380 THAT IS THE LATEST, JERRY
Re: EGR Valve replaced and... [Re: glock] #680651 01/03/06 02:50 PM
HCMP Offline
I would still get the codes pulled. You never know. There have been times where I ruled things out based on coincidence and was wrong.
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.010s) Memory: 0.6378 MB (Peak: 0.7599 MB) Data Comp: Off Server Time: 2026-11-03 13:22:14 UTC
