Truck Overheating #680922 12/29/05 11:21 PM
Y
yotadiehard Offline OP
I have a 88 fuel inject 22re that is overheating. When checking it out, the top radiator hose was sucked in and water was in the overflow. Changed the termostat and now its get up to about 3/4 of gauge and then drops to normal. This will happen once or several times while running it. any ideas?
Re: Truck Overheating [Re: yotadiehard] #680923 12/29/05 11:35 PM
seaflea Offline
Sounds like youÆre Thermostat is stuck. Not hard or expensive to replace.
Re: Truck Overheating [Re: seaflea] #680924 12/30/05 02:16 AM
4x4runner Offline
Re: Truck Overheating [Re: yotadiehard] #680925 12/30/05 02:27 AM
3
355Camaro Offline
real quick, what kind of a thermostat did you put in there? If it's anything other then OEM, it's gonna spike to 3/4 hot then be fine from there on out. Scaret me at first lol, put an OEM one in there (was cheaper then Napa) and now its perfect!
2000 Audi TT 1.8Turbo Quattro
1988 Chevy Camaro - 100% Built + for sale!
Re: Truck Overheating [Re: 4x4runner] #680926 12/30/05 03:06 AM
4Crawler Offline
Yep, sounds like the classic 22RE Temperature Overshoot problem. Live with it or put in the 2-valve t-stat that Toyota designed to fix it.
Re: Truck Overheating [Re: 4Crawler] #680927 12/30/05 12:32 PM
foxtrapper Offline
Or drill a small hole in the thermostat. 1/8" or so will do just fine.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6098 MB (Peak: 0.6795 MB) Data Comp: Off Server Time: 2026-06-07 07:03:49 UTC
