Anyone with a Rancho steering stabilizer as stock replacement? #681186 12/31/05 03:34 AM
E
Eck Offline OP
I had the relay rod done last week by Toyota. Lot's has been written about it. Now my steering dampener leaks. No sign of force from the reinstallation. OK, it's about 13 years old but I find it amazing that it now breaks after the @#$% dealer was at it. Normally I do all my work myself.
Since this truck sits idle all winter and is only used when pulling a trailer, I decided to go with a Rancho replacement instead of the $ 170.- from the dealer. Rancho is supposed to be a direct replacement.
Does anyone has one installed?
92 Xcab V6 4x4 SR5 5sp., Detroit locker rear, lim. slip front, Warn hubs, H4's, electr. fan, eng. oil cooler, 1 lift, open cat.
Re: Anyone with a Rancho steering stabilizer as stock replacement? [Re: Eck] #681187 12/31/05 03:41 AM
ScaldedDog Offline
It's been awhile, but yes. Not much to it. Steering felt a little heavier afterwards, IIRC, as the stock one didn't put up much resistance.
Mark
''Wise men talk because they have something to say; fools,
because they have to say something.'' - Plato
http://www.scaldeddog.com
Re: Anyone with a Rancho steering stabilizer as stock replacement? [Re: ScaldedDog] #681188 12/31/05 03:47 AM
E
Eck Offline OP
Thank you for your post, did it fit into the org. brackets and taper end on the rod side? Or was it a U bolt job? Hope not <img src="/forums/images/graemlins/frown.gif" alt="" />
I ordered it but haven't seen it yet. I'll do the swap tomorrow if it comes in.
Re: Anyone with a Rancho steering stabilizer as stock replacement? [Re: ScaldedDog] #681189 12/31/05 03:49 AM
brentox Offline
I have a rancho setup but the one i have is not a direct factory replacement. There was not much to it just required installation of a bracket and some other hardware to accept the new stabilizer. I am happy with its performance though and i run 35" mud terrains
92 Extended Cab 4x4, 3.0 5-Speed Scratched, Dented and Rusted.
Re: Anyone with a Rancho steering stabilizer as stock replacement? [Re: brentox] #681190 12/31/05 04:00 AM
toy94x4 Offline
It does have the u-bolts, but mine have not loosened up in the two years since I've installed it. It also comes with a bracket that mounts it to the idler arm if I remember correctly.As previously mentioned, you'll notice the steering to be a bit heavier. But after a couple weeks, it'll be like normal again. Just be sure once you install it to have it centered so you get equal movement when steering from side to side. It took me a couple tries, but only 5 minutes worth.
1994 P'up, 22RE, K&N, LCE exhaust sys (header, cat, muffler, 2.25" pipe), 1" RB seat lift, 1" RB body lift, 1.5" rear lift via shackles, Rancho 5000's, 33" Pro Comp M/T's, 4.88's w/ Aussie lockers front & back
Re: Anyone with a Rancho steering stabilizer as stock replacement? [Re: toy94x4] #681191 12/31/05 05:23 AM
E
Eck Offline OP
From what you guys write, it sounds like a good solution even though it's U bolts.
I'll follow up when it's installed. Thank you for your quick replies.
Re: Anyone with a Rancho steering stabilizer as stock replacement? [Re: Eck] #681192 12/31/05 05:54 AM
Scerb Offline
It sounds like you already ordered one, but for everyone's future reference the Pro Comp es2000 stabilizer is a direct bolt-in and I did not notice any difference in steering afterwards <img src="/forums/images/graemlins/kewl.gif" alt="" />
-Scerb
Re: Anyone with a Rancho steering stabilizer as stock replacement? [Re: Eck] #681193 12/31/05 06:14 AM
ScaldedDog Offline
Yeah, the u-bolts work fine. I tore the stabilizer in two this past summer, and the u-bolt end was all that remained attached.
Mark
Re: Anyone with a Rancho steering stabilizer as stock replacement? [Re: ScaldedDog] #681194 12/31/05 06:38 AM
E
Eck Offline OP
Well... if I don't like what I see then it goes back. Also, if the skid plate won't fit in front I won't take it either.
Re: Anyone with a Rancho steering stabilizer as stock replacement? [Re: Eck] #681195 12/31/05 09:08 AM
toy94x4 Offline
The stock skid plate will fit back in place just fine, mine did. I can't speak for any aftermarket skid plates though.
PHP: 7.4.33 Page Time: 0.033s Queries: 16 (0.028s) Memory: 0.6383 MB (Peak: 0.7615 MB) Data Comp: Off Server Time: 2026-11-04 20:00:04 UTC
