Winch Mounting Point on ARB Bull Bar #681544 01/01/06 08:49 AM
langforg Offline OP
I found the winch that I'm going to get. Warn 9000 lb. Does anyone have a picture of how this is supposed to mount into the ARB Bull Bar?
Brad <img src="/forums/images/graemlins/confused.gif" alt="" />
95 Trooper,3in Lift,15x10 AR-23 Wheels, 33x12.50 BFG AT's, SuperWinch Hubs,Rock Sliders,Tie-Rod Shields,Cross-Drilled Brake Rotors,ARB Bull Bar...,looking for cheap winch.
Re: Winch Mounting Point on ARB Bull Bar [Re: langforg] #681545 01/06/06 06:25 AM
langforg Offline OP
bumpity bump
Re: Winch Mounting Point on ARB Bull Bar [Re: langforg] #681546 01/06/06 06:34 AM
randii Offline
Here's a link to an older feature with a Trooper equipped with an ARB front bumper: http://www.4x4wire.com/isuzu/news/SEMA2001/compass.htm
This picture doesn't QUITE show it, tho! <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Randii
Re: Winch Mounting Point on ARB Bull Bar [Re: langforg] #681547 01/06/06 06:46 AM
randii Offline
Which winch do you have? This pic shows one with an external, non-integrated solenoid pack:
Randii
Re: Winch Mounting Point on ARB Bull Bar [Re: randii] #681548 01/06/06 08:41 AM
langforg Offline OP
looking at getting the Warn XD9000.
Part Numbers: PN 28500 CE (12V DC) , PN 265012 CE (24V DC)
Rated Line Pull: 9000 lbs. (4080 kgs.) single-line
Motor: 12V 4.6 hp, 24V 2.5 hp Series WoundTM
Remote Control: Remote switch, 12' (3.7m) lead
Geartrain: 3-Stage Planetary
Gear Ratio: 156:1
Lubrication: Aeroshell #17
Clutch (freespooling): Sliding Ring Gear
Brake: Automatic Direct Drive Cone
Drum Diameter/Length: 2.5"/9.0" (6.4cm/23cm)
Weight: 78 lbs. (35 kgs.)
Wire Rope: 100', 5/16"diameter (30m, 8mm diameter)
Fairlead: Roller
Recommended Battery: 650 CCA minimum for winching
Battery Leads: 2 gauge, 72" (1.83m)
Finish: Argent Powder Coat
Nuts/Bolts: PN 39625
CE Winches: CE products are designed to meet European Standards. CE winches include CE labels, manuals, roller fairlead, safety hook and thimble.
12V DC PERFORMANCE SPECS
Line Pull
Lbs.(Kgs.) Line Speed
FT./min(M/min.) Motor
Current Pull by layer
layer/Lbs(Kgs.)
0 38(11.6) 70 amps 1/9000(4082)
2000(910) 14.4(4.39) 180 amps 2/8190(3715)
4000(1810) 11(3.35) 255 amps 3/7500(3402)
6000(2720) 8.67(2.64) 330 amps 4/7010(3180)
8000(3630) 6.88(2.10) 415 amps
9000(4080) 6.38(1.94) 460 amps
Re: Winch Mounting Point on ARB Bull Bar [Re: langforg] #681549 01/06/06 10:26 PM
randii Offline
The XD9000 is one of the more compact winches out there -- it should fit well into just about any bumper made to carry a winch... the separate solenoid pack makes it nice and small.
Randii
Re: Winch Mounting Point on ARB Bull Bar [Re: randii] #681550 01/07/06 01:49 AM
langforg Offline OP
I'm still not that sure on how to mount the winch. I have the bumper like in the first picture. The fairlead is on the very bottom of the bumper and I don't see any kind of bracketry or mounting holes down there to mount a winch to. Is mounting a winch a custom job? I have the tools and ability, but I was under the impression that a winch was just a bolt on with an ARB Bull Bar.
Re: Winch Mounting Point on ARB Bull Bar [Re: langforg] #681551 01/07/06 02:27 AM
randii Offline
Have you called ARB? This winch should just bolt in, no custom work required.
It may sneak in from the bottom and bolt in before the bumper goes on, don't know.
Randii
Re: Winch Mounting Point on ARB Bull Bar [Re: randii] #681552 01/07/06 03:04 AM
TrooperJ Offline
Also contact Wareagle or Tad on here, and try asking on the planet. They both have ARB's (i think, right?) and could probably tell you how it goes.
-J <img src="/forums/images/graemlins/kewl.gif" alt="" />
Jordan Brown in Athens Georgia
The 2007 budget for the US Military covers Jack Bauer, two pistols and four billion rounds of ammunition.
Re: Winch Mounting Point on ARB Bull Bar [Re: TrooperJ] #681553 01/07/06 07:28 AM
langforg Offline OP
thanks...good idea
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6407 MB (Peak: 0.7662 MB) Data Comp: Off Server Time: 2026-10-24 13:11:37 UTC
