22 R engine id #s #682004 01/03/06 03:59 AM
tgzzzz Offline OP
Where can I look for a list of what serial #s = what year an engine is? My aftermarket manual doesn't include them, and the page on Marlincrawler doesn't match up with what I'm seeing. Mine is something like 196775...it's kinda hard to read as engine is still in truck.
I've been looking at some used engines lately to rebuild and have encountered a number of folks who apparently just will say anything or are simply clueless.
Popping the exhaust manifold off or removing the valve cover would help but my sellers are not too keen on those ideas. A guy told me today that a (manifold-less) 89 RE engine couldn't replace an 87 R. My research on this site suggests that the real distinction is the 84/85 change in block height, piston design, ex port shape, and timing chain.
Does an RE engine have the RE stamped on the block near the engine ID?
Thanks
Re: 22 R engine id #s [Re: tgzzzz] #682005 01/03/06 04:55 AM
kewlynx Offline
The serial numbers you could run at the dealership I believe. Nope; they're simply etched 22R. Last carbie year was 87/88.
There is a cast date on the pax rear corner of the block, but you have to take the oil pan off to see it, and to me it's moot. [edit] EG, I picked up a 22RE L/B this summer, rebuilt; the cast date was '84, but all the hardware is correct.
Ex manifold for EFI has the 02 sensor mounted. I don't know if Kali carbs had them or not; maybe one of them here knows.
If the head is still on, take the valve cover off (those yahoos will just have to get over it <img src="/forums/images/graemlins/rolleyes.gif" alt="" />). On the pax side, an RE will have a closeout plate where the fuel pump for a carb config lives. NOW, if you look at your truck's head, you'll see a wheel(right term escapes me) that your fuel pump flipper rests on just in front of the cam gear. An EFI won't have that; it'll have a spacer instead. Only exception would be is if someone did an EFI conversion, and simply left it in there; it doesn't affect anything.
Guy you talked to is clueless. HOWEVER, if you're looking to do an EFI changeover, and he's got all the goodies, grab 'em,the ECU, and fender components as well. <img src="/forums/images/graemlins/notooth.gif" alt="" />
On the pax side, there is a fairly large threaded hole near the oil filter mount that's for a knock sensor. You won't see this on a carbie. Check your truck. Also, if the engine was yanked and the fuel filter bracket was left on, you'll see that too.
The long block itself will interchange, with exception to the +/- 84 years, as you already know. <img src="/forums/images/graemlins/cheers.gif" alt="" />
**ubi apis- ibi salus**
Re: 22 R engine id #s [Re: tgzzzz] #682006 01/03/06 05:01 AM
dentcollector Offline
My 22r has a stamp just to the right of the block number. It is on it's own little flat casting just like the block number is. Shouldn't be any secret code involved just scrape away the grease and or grime.
1988 4Runner V-6 Auto, Locked out back, LSD up front, some lift, some tire, and a casual attitude towards body damage.
Re: 22 R engine id #s [Re: dentcollector] #682007 01/03/06 05:22 AM
kyle-22r Offline
and for the record, all '85-95 22R and 22R-E engines without the manifolds are interchangeable, and the same internally(besides maybe a few cam differences, but they're all compatible)
'91 4x4 shortbed
22R-E, W56, the dd!
Re: 22 R engine id #s [Re: kyle-22r] #682008 01/03/06 06:03 AM
tgzzzz Offline OP
Yep, yep, that's what I thought, and thanks. I meet so many people who are rarely correct but NEVER in doubt.
And Kewl, your comment about the casting year being moot (as long as it's post 84+/-)is well taken although I think there are some states where it's not OK to put an older engine in a newer vehicle. We don't care about that stuff out here in the saltmarsh. As an ex-teacher, I'd also like to give you an A for your use of the woefully-misunderstood semicolon. <img src="/forums/images/graemlins/kewl.gif" alt="" />
87 JX Zuke bone stock almost cherry
86 Heavy Chevy 350 one ton 26' RV
There's always time to do it over.
Re: 22 R engine id #s [Re: tgzzzz] #682009 01/03/06 06:40 AM
kewlynx Offline
Hehe! Yep, it breaks up a run-on sentence. <img src="/forums/images/graemlins/notooth.gif" alt="" /> FWIW, I don't live in one of those states either! <img src="/forums/images/graemlins/pfft.gif" alt="" /> I'd like to see an inspector take an oil pan down off an IFS vehicle! <img src="/forums/images/graemlins/evil.gif" alt="" />
Speaking of oil pan, make sure that's the FIRST thing you yank; what's left in the bottom tells you a lot about the engine's history. If you find TC parts in there, count on finding a whanged piston; this IS an interference engine!!
You can also use a L/B out of a 2wd. Change over the oil pan, the dipstick, and its holder. IIRC, there's about an inch difference, and you're ready to move ahead. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 22 R engine id #s [Re: kewlynx] #682010 01/03/06 06:48 AM
kyle-22r Offline
hmm, never was aware of any differences between the 2wd and 4wd dipsticks! the 22R i put in my '79 was from a celica, and i swapped a 4wd oil pan in and used the dipstick and tube that it came with. still reads full at 4.5 quarts <img src="/forums/images/graemlins/cheers.gif" alt="" />
'91 4x4 shortbed
22R-E, W56, the dd!
Re: 22 R engine id #s [Re: kyle-22r] #682011 01/03/06 07:39 AM
kewlynx Offline
I discovered that with the JFE engine from hell. That was when I concluded idiot boy sent me a setup out of an 82 Celica. A friend had one I could look at. Ex manifold head bosses were set up to fit a 20R manifold. <img src="/forums/images/graemlins/angry.gif" alt="" />
Re: 22 R engine id #s [Re: tgzzzz] #682012 01/03/06 08:00 AM
4WD22R Offline
Copy down the number and give the stealers a call, they'll know what year/month the block was cast--well close enough anyway, they are missing some numbers but should be able to tell you close enough to be able to figure out the year.
Yeah, it's amazing what some people will tell you....even shops that are SUPPOSED to specialize in Toyotas.....idiots.
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: 22 R engine id #s [Re: 4WD22R] #682013 01/03/06 08:09 AM
kyle-22r Offline
i haven't looked at block casting numbers, but on a lot of other parts(front end parts especially) the year/month/day is cast into them.
'91 4x4 shortbed
22R-E, W56, the dd!
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6448 MB (Peak: 0.7713 MB) Data Comp: Off Server Time: 2026-11-17 06:24:41 UTC
