Strange transmission problem... Fixed itself the next day?!? #682093 01/03/06 03:11 PM
Seven Offline OP
99 4runner Limited...
The other day we had a large amount of wet and heavy snow/slush fall in a short period of time. I had about a 20 mile drive home in the stuff, so I threw it into 4high. I didn't have any problems getting home, however when I arrived, I couldn't shift gears past neutral!
By putting pressure on the handle, I was able to engage reverse, though the stick didn't actually lock into that posiiton. I took it out of 4high, when forward and reverse a few times... No luck. I left it in neutral overnight with the parking break on.
The next day, I could shift smoothly into all gears but PARK. By the second day, no problems at all, PRD2L all good to go like the day I bought it.
Any ideas?
You know how you have to break to shift into park? I'm wondering if that sensor temporarily crapped out somehow due to the weather conditions.
Re: Strange transmission problem... Fixed itself the next day?!? [Re: Seven] #682094 01/03/06 07:13 PM
Seattlegti Offline
Might check the fluid level and fluid condition in the trans. Lockout switch might have gotten wet or stuck.
Re: Strange transmission problem... Fixed itself the next day?!? [Re: Seven] #682095 01/04/06 02:46 AM
Dandeman Offline
Toyota Moderator
What about the possibility of frozen slush being thrown up into the linkage and freezing into position....
Re: Strange transmission problem... Fixed itself the next day?!? [Re: Dandeman] #682096 01/04/06 04:16 AM
bkg Offline
my thoughts.
Brian K. Gallus
Re: Strange transmission problem... Fixed itself the next day?!? [Re: bkg] #682097 01/04/06 02:32 PM
Seven Offline OP
my thoughts.
That's a strong possibility, I was hot-dogging it pretty hard on my way home. Slush flying everywhere...
You'd think that area would be sealed off better.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6050 MB (Peak: 0.6694 MB) Data Comp: Off Server Time: 2026-06-10 00:08:27 UTC
