Q about threads for block port #682820 01/05/06 04:37 AM
J94_4runner Offline OP
Ok, on my 5M theres a port on the side of the block thats part of the oil system. I bought a 1/8" NPT brass plug for it today and it's about the right size, but doesn't wanna start. I've heard some talk about BSP thread... is that what toyota uses?
www.celicasupra.com
Re: Q about threads for block port [Re: J94_4runner] #682821 01/05/06 06:03 AM
OOP'S Offline
They are Metric threads, you need to get an adapter like you use when you put on an aftermarket oil pressure gauge or find a place that sells metric brass fitings......
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Q about threads for block port [Re: OOP'S] #682822 01/05/06 04:59 PM
ok, so when you say metric... just metric... like a bolt? Or metric Pipe thread? or what exactly ?
www.celicasupra.com
Re: Q about threads for block port [Re: J94_4runner] #682823 01/05/06 06:38 PM
4Crawler Offline
Hard to say which it is, but there are 3 sizes all about the same physical size, 1/8" NPT (0.407" OD, 27 TPI), 1/8" BSP (0.407" OD, 28 TPI) and M10x1.0 (0.394" OD, 25.4 TPI) <- this is what the brake line fittings use.
I have made use of a greased 1/8" NPT pipe thread tap to modify threaded holes, like for my diff. breather fittings. They are not a high pressure fitting and with a bit of Teflon tape, they seem to seal up just fine.
Re: Q about threads for block port [Re: 4Crawler] #682824 01/05/06 07:16 PM
willzrunna96 Offline
if you cant get it "behind the counter" at a parts store check to see if they have that sunpro kit for the oil pressure gauges 98% sure its in there
Re: Q about threads for block port [Re: willzrunna96] #682825 01/05/06 10:06 PM
Looks like it's M10x1.0. WHy.. b/c my 10x1.25 bolt started to thread but didn't go much. So i'm betting it's the M10x1.0 thread. just can't find anyone that stock a plug in that size!!!
www.celicasupra.com
Re: Q about threads for block port [Re: J94_4runner] #682826 01/05/06 10:58 PM
4Crawler Offline
You could use something like this:
- http://www.amstreetrod.com/961503ERL.php4
An M10x1.0 to AN brake line adapter then add an AN cap to seal it off.
Or pickup up an M10x1.0 oil pressure or temperature sender and hook up a guage:
- http://egauges.com/eg_sType.asp
Re: Q about threads for block port [Re: J94_4runner] #682827 01/06/06 12:47 AM
benmlee Offline
The oil pressure port on the 22RE does use a british 1/8" pipe thread. You can get them at Autometer or at McMaster. The normal 1/8" NPT will go in, but only for about a turn or so.
Ben
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6232 MB (Peak: 0.7214 MB) Data Comp: Off Server Time: 2026-06-13 10:44:26 UTC
