Screwy idle #683783 01/08/06 01:38 AM
TinyTruck Offline OP
was having a problem last night with the idle on my 1994 4-runner w./ 22re.
The usual idle on this pig is about 5-700rpms. While sitting in my friends driveway idling away with the pedals tottaly clear the idle jumps to about 3000rpms, then drops down to about 1700-2200rpms where it fluctuates from that range to about 3300rpms. At this point I stab the gas to bring it to about 6000rpms, when I let off it dropped down to about 1000rpms where it stayed for a second and then jumped back up to the 1700-2200rpm range again where it stays for about 30seconds. After all of the above it settled down to the 250-500rpm mark (acceptable?).
The whole time it sounded as if it had a lumpy cam in it
1988 YOAT "Stumpy"
-Lock-Right -Fabtech spare tire carrier
-3in PA BL -Custom Flatbed
-32x11.5 cooper mall-terrains <BALD>
Re: Screwy idle [Re: TinyTruck] #683784 01/08/06 01:46 AM
4Crawler Offline
Check your Throttle Position Sensor:
- http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Make sure the throttle plate is not sticking (maybe dirty inside) and that the dashpot is moving freely:
- http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml#Dashpot
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5910 MB (Peak: 0.6394 MB) Data Comp: Off Server Time: 2026-06-07 02:24:37 UTC
