Page 1 of 3 1 2 3
brakes??? #684337 01/09/06 01:41 PM
urso8up Offline OP
HAs anyone upgraded there brakes system in anyone for better stopping ability. or for even better brakes. My truck shakes when i am braking??
1998 T100 4x4 3 body lift 4 procomp suspension 15x10 steel wheels and 35x12.50x15 Baja Claws
http://www.cardomain.com/id/urso8up
Re: brakes??? [Re: urso8up] #684338 01/09/06 04:22 PM
surlynkid Offline
i have rear disks.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: brakes??? [Re: urso8up] #684339 01/09/06 05:45 PM
jmoser Offline
Maybe your front rotors are warped? This is said to be common on the T100s.
I replaced with Brembos and ceramic pads at ~75K. I am pretty easy on my brakes, lots of highway cruising and use lower gears for downhill coasting w/o brakes at all.
I don't think my rear brakes do much - they still look like new after 80K. Maybe my proportioning valve should be adjusted.
Don't forget to drain and bleed new brake fluid on all 4 wheels periodically.
Maybe I will upgrade to rear disks at 100K or whenever they need replacing. If I am correct it can be about $1000 for the whole kit? Should be a pretty easy install though.
Who makes those parts kits Scott?
Jeff
96 T100 SR5 4WD Ext Cab, Warn Hubs, HD torsion bars, Bilsteins, Camper Shell, TJM bar, factory 31 x 10.5's, Powertrax No-slip rear, Recaro driver's bucket
Re: brakes??? [Re: jmoser] #684340 01/09/06 06:37 PM
urso8up Offline OP
Thanks guys
I was thinkning of ordering new rotors anyway just to see if it helps the problem but just wanted to get feed back on the brakes before hand .... Thanks for the fast response.
Re: brakes??? [Re: jmoser] #684341 01/09/06 07:23 PM
adam Offline
~Adam
Re: brakes??? [Re: jmoser] #684342 01/09/06 08:24 PM
surlynkid Offline
front range off road. i have a write up here on the board. it is probably closer to $1300 when you are done buying calipers unless you can find them in a junkyard. it is a really slick setup. i like it. i hate drums with a passion.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: brakes??? [Re: urso8up] #684343 01/09/06 10:30 PM
Kookadala Offline
I put cross drilled rotors on the front and they have worked great for me. The only problem is when I am leaving the driveway and the first time i hit the brakes at the end of the driveway while they are cold they dont seem to grab very good, but after that they are fine and stop my 35s without trouble.
You can adjust the load proportioning valve on the rear axle upwards to force the rear brakes to engage more often, this would help you stop.
Shuddering front end while braking is definately warped rotors.
96 T100 4x4 - 35's, 4" SL, 2" BL, 4.88s, ARBs, custom bumper & E9000 winch, etc.
99 F-350 4x4 superduty supercab turbodiesel longbed
Re: brakes??? [Re: urso8up] #684344 01/10/06 12:42 AM
dogslovetrucks Offline
sounds like warped front rotors to me too... you may want to check the front bearings while you are in there and whatever you do, dont get the rotors resurfaced.... trust me.
Re: brakes??? [Re: surlynkid] #684345 01/14/06 07:41 PM
speedlever Offline
I have always been interested in converting the rear drums to disc brakes. Unfortunately, you lose ABS in the process.
OTOH, my ABS isn't working anyway.
OTOOH, $1300 is a lot of $$ to change the brakes.
OTOOOH, I've been having rear brake trouble ever since I had the rear axle bearings and seals replaced. Sometimes the rear brakes won't release until the truck moves slightly backward.
OTOOOOH, I'm not sure how much longer the T will be able to stay around... given the rear seat passenger safety issue that I belatedly realized.
--speedy
White '98 T100 SR5 4x4 ExCab Auto - wrecked.
2008 Honda Ridgeline RTS replaced the T100.
Re: brakes??? [Re: speedlever] #684346 01/14/06 08:05 PM
Jake97T Offline
trading in my truck for a Subaru WRX Sti sounds real nice sometimes to me....which would solve my lack of power issues, leaking valve covers, rubbing tires...etc
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.006s) Memory: 0.6346 MB (Peak: 0.7592 MB) Data Comp: Off Server Time: 2026-10-21 18:58:23 UTC
