Fuel pump swapping #684371 01/09/06 03:45 PM
RSimister Offline OP
Just got the call from the wife.My truck just died.She says its not getting fuel.It's an 89 trooper 2.6.The other one we have that just got retired because it won't pass an emission test is a 90 2.8.If it turns out to be the pump,will the V-6 pump work on the 4 banger? I haven't got home to look at it so it could be a relay,wiring or fuse but in case I'd rather know in advance.
Re: Fuel pump swapping [Re: RSimister] #684372 01/09/06 03:57 PM
Richard Saylor Offline
Won't work. The 2.8 one is TBI. The 2.6 is MPFI. TBI uses about a LOT lower of a psi pump than the MPFI does. Wouldn't work. I'd make sure to check the wiring and everything. The harness on top of the tank seems to be a bad spot.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: Fuel pump swapping [Re: Richard Saylor] #684373 01/09/06 04:05 PM
Gonna check it out tonight when I get home.We had a problem like this once before with the wiring on top of the tank.I soldered the connections and covered them in a puddle of GOOP.Other than that we have had no grief with this truck in 100000 km (62000) miles.Not bad for $450 cdn and a new cylinder head.
Re: Fuel pump swapping [Re: RSimister] #684374 01/09/06 04:10 PM
greauxpete Offline
get one on car-part.com...
1990 Isuzu Trooper 2.8L V6
Re: Fuel pump swapping [Re: greauxpete] #684375 01/09/06 05:01 PM
Not up here in Canada
Re: Fuel pump swapping [Re: RSimister] #684376 01/09/06 07:30 PM
barak Offline
If it turns out to be the pump , messageme later and I'll sell you my pump from my 89 2.6.Its sitting in my basement and I don't need it anymore.I was gonna stick it with everything else for the engine when I sold it , but never did sell the engine and tranny yet.
Re: Fuel pump swapping [Re: barak] #684377 01/10/06 04:37 AM
mlclark Offline
Isuzu Moderator
Don't got with a used pump. It is enough of a headache when it dies, you are just rolling the dice with used.
Down here, replacement pumps go for about $80-$100. Well worth the investment to do it just once in your lifetime. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6174 MB (Peak: 0.6917 MB) Data Comp: Off Server Time: 2026-06-10 01:42:14 UTC
