good price for frame?
#684554
01/10/06 01:01 AM
There's a junkyard nearby who has a '91 4cyl 2WD that and wants $350 for the frame. Is this a good price? I've already given it a thorough check using my frame tester (4# sledge). Hopefully I can get him to throw in the gas tank and steering box. Also does anyone know what is involved in matching up the 3.0 mounts to a 4 cyl frame? Do they bolt up just the same or is more modification required?
1989 3.0 5 spd extended cab with more rust than should be legally aloud, soon to have a D44 front and D60 rear
Re: good price for frame?
[Re: Digital_Aardvark]
#684555
01/10/06 01:14 AM
Should be no problem at all with the mounts. I'd try and get a rolling chasis though. It'll make your life much easier when you go to do the swap.
(aka suprathepeg, aka Sean) 89 v6 SWB truck "BLACK BEAUTY" EB valves, P&P head 30 over. 95 FZJ80. Lifted. locked and rollin on 33s (my dream machine)
[Re: Rauch_Off_Road]
#684556
01/10/06 01:24 AM
i suppose you are right, but I forgot to mention that I am going to do a SAS. I've already got the 44 front a 60 rear to swap in. I was planning on building the frame up first and getting the axles on, then swap everything over (so I am only without a vehicle for a limited time)
#684557
01/10/06 03:27 AM
If you're doin and SAS from the frame up then why waste your time with the 4x4 frame? Get yourself a 2wd frame the arches are higher and your not gonna be any further behind then with the 4x4 one, might be bit cheeper too.
#684558
01/10/06 03:30 AM
Toyota Moderator
#684559
01/10/06 03:31 AM
#684560
01/10/06 03:39 AM
Yea exactly thats what I said <img src="/forums/images/graemlins/shiner.gif" alt="" />.
Sorry that was a silly oversight. Sounds like a good plan then. I checked around here and frames are about $200CAD if they are minty. I don't know about availability there though. I'd try and get as much attached as possible.
#684561
01/10/06 03:49 AM
that's a little steep for a frame IMHO. if you're going to do an SAS, it's a good base to start with, though <img src="/forums/images/graemlins/cheers.gif" alt="" />
'79 sport 4x4 longbed <img src="/forums/images/graemlins/smile.gif" alt="" /> 20/22R hybrid with EB's OS valves, 268c cam, offy intake, weber 32/36, thorley header, 5 speed swap, 34" LTBs, downey 3" springs, marlin hysteer, 4.88s and locked
'91 4x4 shortbed 22R-E, W56, the dd!
[Re: kyle-22r]
#684562
01/10/06 05:03 AM
I paid $40 for the 85 shortbox frame that's strapped to my Mom's deck...
Yes, she's a redneck. <img src="/forums/images/graemlins/smile.gif" alt="" />
Brian K. Gallus I have nothing important to say.
[Re: kyle-22r]
#684563
01/10/06 06:36 AM
I know its a the price is a bit high, but to be able to find anything else in good shape would require me to travel out of the rust belt. I am going to stop over there tomorrow morning (actually later today since its past midnight) and pay for it <img src="/forums/images/graemlins/cheers.gif" alt="" />
